89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I have the eraser wheel, but it only works for the glue. I can get them off with wax, but it takes a lot of elbow grease. Haven't tried a clay bar yet.
Good point, I didn't think of the clay bar. Good luck. Let us know how it goes.
RooTBeeRthe1st
Ltzjeff
Chicago Suburbs
Even though it was 79 today - new rims and tires for soon to be here winter.
Charlie207
LFOD, New Hampshire
Installed a set of Husky mud flaps. It will be nice not to have slush mounds and mud splatter built up on the fenders/rockers/running boards/exhaust tips.
View attachment 376310View attachment 376311
How are the Husky mud flaps holding up? Do they do a good job reducing spray from the front tires?
I'm thinking about getting a set of F&R to try and minimize the salt spray this winter.
i've had the husky's on mine for 3-4 years now still holding up nicely like they were oem, they do reduce slinging of crap to about 1/2 or more of what it is without any mudflaps
89Suburban
SE PA
Well chit. I drove thecopcar to the dog park. The left front speaker is intermittent. No rears to fill in so it’s obvious. And annoying.
I just went through this. I thought the speaker was taking a crap. And I dreaded that because they run around $100 bucks for the Bose replacement. Before ordering it I pulled the panel off to do a test run of removing the speaker and comparing pictures of it to the new ones I was shopping. In the process I found it wasn't the speaker, it was the connector. The plug connections were corroded causing intermittent signal. I ordered a replacement plug and it worked perfectly:
89Suburban
SE PA
Thanks, I think I'll move forward and grab the set.
Funny you should ask!!! I took these pictures this morning on my way to work. It has been raining for 3 days and the leaves are falling making the roadways a mess. They are doing a DAMN FINE JOB!
Sparksalot
Bastrop County, Texas
That’s a good point.
Charlie207
LFOD, New Hampshire
Sparksalot
Holy carp, what happened to speaker prices? I got a new rear one 2 years for about $25.
Check to make sure your door drains aren’t plugged up. The wiring in your doors shouldn’t be rusting imo.
Phlipnstik
