Paint touch ups and rust repair
992dr
Eastern N.C.
Damn, you're making quick work of it. (Did I say that in another post haha)
If you were closer to me, I'd give you some material and consumables in exchange of you doing this to my Tahoe :)
tungsten
tungsten
Working on passenger fender. Pretty rusty underneath and about 3/4” up. Started with the vertical piece.
Got that sitting Flat. Made a template from the other side for the horizontal piece that goes underneath
welding it up on the bench and I ran out of gas for the welder. Crap To the store tomorrow I go.
tungsten
tungsten
Well about a thousand tack welds later. I’m low right where the welds are so worked good don’t have to grind welds any more. Haven’t done a light test yet. I’m sure I missed a few spots.
Did the cut and butt where you over lap then cut at an angle. This way when the panels close the gap gets smaller. Got it off a video. Worked well. My pic of the cut off wheel is exaggerated,about a 30*worked good.
tungsten
tungsten
Sanding bondo sucks.
Don't remember seeing if you got OE paint using your paint code? If so, how's it lookin?
I just got a couple of cans for my Tahoe.
Yeah I got some different paint from my paint code.707 Dark Labyrinth.The shop had 3 swatches for that code so hopeful.
Later tonight Ill do a test spot.
tungsten
tungsten
Working on this while bondo cures.
The bondo project. Have a high spot in the metal on the lower left. Tried beating in but didn’t move its right on bead right Where the backside is welded. I think I have to grind it down.
992dr
Eastern N.C.
Ahh very cool. All the locals want to retire on a sale, so I went through gmparts and got my paint code and cans online.
I'll have to read up on blending peeled paint haha.
You're making some progress man, nicely done. Giving me a little inspiration :)
tungsten
tungsten
Im just a hack,Maybe fussier then some.
tungsten
tungsten
The colour of the primer made the first 2 coats look blue. I sprayed 4 light coats to hide the primer. These cans are 90% solvent so takes a few coats. I sprayed pretty thin also. Colour matches much better then my first can once the primer disappeared.
I’ll wet sand and spray again tomorrow.
tungsten
tungsten
Well hell, it doesn't look like hack work to me, and the finish is coming out pretty nice.
Thanks,Ive done the odd touch up before but never to this extent.
Living in snow and salt I dont expect these repairs to last a long time.
tungsten
tungsten
Need some recommendations for mud flaps for this Yukon.
The running boards have done a good job of protecting the rockers.I was expecting rust when I removed them but their pretty good.
992dr
Eastern N.C.
I have never got into body work before.
Coming from Boston down to NC. I've owned quite a few vehicles up there, never had any rust issues. Not sure why.
Bought a retired PPV from Raliegh and the rockers are gone, go figure haha.
You know, I don't think I have ever seen mud flaps on a GMT900 before.
Oh and I'm jelly of your HD. I just noticed this was on a 2500 in your sig :).
I'd like one of them next if I can find one.
tungsten
tungsten
Sanded over last nights test. Could still see my primer line so did a bit more 400 wet to disturb the line.
3 more coats of base kinda blended in and I’m on 3 coats clear. Learned my lesson on the last go. Not trying to blend clear I’ve sprayed the whole bottom this time.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Nice work there man, you got skilz and patience for that body work stuff. I HIGHLY recommend the Husky flaps. Here is a link to look up your truck and a few shots of mine installed. Fairly easy to install. A right angle adapter for your impact driver will help you work around the tires without having to remove them.
tungsten
tungsten
3 more coats of base kinda blended in and I’m on 3 coats clear. Learned my lesson on the last go. Not trying to blend clear I’ve sprayed the whole bottom this time. View attachment 383503View attachment 383504
Well colour match sucks. Back to the shop I go again.
tungsten
tungsten
Working on lower wheel well in front of rear tire. Gave it a hit with a hammer and it all came crumbling down. Must be some structure behind as what’s left is pretty thick metal.
The bottom piece seams easy enough a couple of lips and done. The side piece however has two curves one in and one out but only a little. A friend borrowed me his home made English wheel. Seams to work just gotta keep at it.
89Suburban
SE PA
The bottom piece seams easy enough a couple of lips and done. The side piece however has two curves one in and one out but only a little. A friend borrowed me his home made English wheel. Seams to work just gotta keep at it.View attachment 383585View attachment 383586View attachment 383587View attachment 383588
I have had more than my share of that and trying to fix them, do not miss that at all.
CKendrick
