Replacement plastic bracket for 2003 yukon denali driiver side master lock/window switch
Hambone1951
Hi, I am hoping someone knows what the part number is or where to buy a replacement for the white L shaped plastic bracket attached to the door panel that the master switch assembly snaps into. Mine is broken and would like to replace it. Thanks!!
Picture? I repaired the screw tower that holds the Driver's Door Module (the switch) bezel with Q-Bond when mine was broken. Not sure if this is what you're referencing but post up a pic of the broken parts.
H
Hambone1951
Hi Fless, Here is a picture. I may have to do something similar as you or let it be loose. Forward end is fine. I took the screw out before removing.
H
Hambone1951
Thanks all for the quick help. Very nice forum. Have had my 2003 since new. Went from hero to zero and its been a good companion during the run. Will definitely continue here and hopefully be able to contribute. Will put some adhesive on the bezel.
I'm not sure that the Q-Bond would fix that (if you have the other part for it), and it's not the bezel. And I don't recall if that part is easily removable. Might be best off just getting a pre-owned door panel from the junkyard or UPull. Or seeing if you can just grab that part off of another truck.
Melram
CA
I’m having this same exact issue but it’s on my 2003 GMC Yukon XL Denali AWD. It’s on both driver and passenger side. I don’t know what the part is called but it is white plastic that is in pieces now. Are you able to repost that parts explosion as I clicked on the link and it is no longer working.
Blackcar
This is link to breakdown for door trim, but most parts are discontinued but gives part number to search for part needed good luck.
Durobans
