randeez
not so much a hintIt’s a hint to get rid of the cats
headers for this pos are like $2k+ and theyre cunty about selling catless anymore.
not so much a hint
i guess its a possibility, would have been when it was at dealership though, and shit sits low as hell though. i didnt even want to try and jack it up to look at it myself. i brought it over to friends shopMaybe someone legit was gonna try to steal them. My fiancé just got warned by her school system that the school parking lots have been getting hit by cat thieves lmao.
Man Ian looks like it’s headed right at you Dan according to tonight’s news. I sure hope not. Really hoping for the best for all you guys over there.![]()
How ya holding up, Dan? It looks like it’s moving slowly, still headed your way. I’ve been watching the weather channel and this one looks big.
Update: I just heard one reporter say he’s covered over 90 hurricanes over 30 years and this one is the worst he’s seen as far as damage.
Dan, sounds like even though the voltage is there the line can’t carry the current. Time to work your way back. But, first, is the relay good?Smart people hear this and help.
I’m getting power to the truck female connector that plugs directly to the top of the pump/bucket. However when plugged into the pump nothing happens.
If I Hotwire a battery directly to the male connector on the top of the fuel pump, the pump comes on.
However, if I jump wires directly from the male connector getting power to the female connector on top of the bucket nothing happens.
It acts as if when the power and ground from the truck harness connects to the pump they zero each other out. I multimetered them directly before touching them to the pins on the pump and they had power. Once I touch them both to the pump they both read nothing.
dibs on the rangerConfirmed relay is good and when key is turned the plug gets a strong 12v, ground, 5v reference, and basically nothing to the 4th pin because that is the fuel gauge return signal line.
Not being able to handle the current was my thought as well, but I’m starving and going mad at hearing hurricane noises inside a tin box for several hours lol. I have since retreated to home where bae has food waiting, it could be our final meal.
Harness from the connector to the pump is bad, like, in the sending unit?Confirmed relay is good and when key is turned the plug gets a strong 12v, ground, 5v reference, and basically nothing to the 4th pin because that is the fuel gauge return signal line.
"Everything is edible if you're brave enough"these bae's you speak of...theyre edible?![]()
if you can call being extra moist is an issueSo no issues with the storm @Dantheman1540 ?
Even if it's a sloppy seconds extra moist?if you can call being extra moist is an issue![]()
