Lowered 21+ T1xx: Post Em Up
DaveLaz
Would it be stupid to lower the z71? I am thinking of adding the black wheels but don't know if I want to go with all terrain tires and keep the off road spirit, or treat it like a concrete jungle cruiser.
I LOVE that idea. I can’t wait for fall to come so I can throw some beefy AT’s on my lowered Tahoe. Such a cool look imo
svt1998gt
DFW
Same here, I am caught in the middle of lowering or leveling it with 22s don't know what I want to do yet.
Capsaicin
Hey all, looking for ideas on how to slightly lower my Tahoe LT (4wd w/ LM2) by maybe an inch or so, while keeping a comfortable ride.
So far I've been thinking about:
* Getting the PPV springs/shocks (lowers only about 20mm)
* Installing the Belltech adjustable shocks and using stock springs (lowering only an inch front and rear)
* Installing the Belltech adjustable shocks and using PPV springs
* Getting the Belltech coilovers and lowering an inch (worried these will contribute to a stiff ride)
* Getting the Bilstein + ground clearance shocks w/ PPV springs (installing Bilsteins at factory ride height)
Any feedback on the above options?
2022
Keep us posted please.
Finally all done. Honestly it's rides like stock. Very happy with the kit, it's a quality product. Have 24in wheel with 285 40 24. No rubbing
wendal
Dallas
So what kit did you use? Did it work with Magnetic Ride Control? Those don't look quite like factory rims. What is the offset on the rims? Thanks for the pictures, it looks GREAT!!!
starbai
Great cars you had, oof e91 6spd that’s not common I wish I had one of those. E36/E46 tough choice between the two! I wanted an e36 or e46 to accompany the e39 for the longest time but I’m leaning towards an early 00’s 911 now, switch it up a bit. Prices are going up get your hands on whatever comes your way soon!
Thanks! No they didn’t unfortunately. I’m still trying to work that out actually, can’t seem to find the front and rear specs for factory studs so I can order and install longer ones. Offset on the wheels are +27
Sorry if I missed it. I read through the entire thread. @DaveLaz did you ever work out what to do with your spacers? In this pic are you running the 1/2 spacer on the stock studs? If so any trouble doing so? Enough bite for the lug nuts? If not, I'm assuming you're trying to work out what to do to extend the studs so that you can run your spacers. Any update? Were you able to do so?
2022
DaveLaz
I was using lugs with a sleeve that screwed past the conical seat about .3”. That made up for most of the spacer taking up thread room. I got a lot more turns when tightening and felt very safe and no issues for about 5k miles until I removed them. I’ve been on OEM RST wheels with my standard lugs until I get new tires on the 24’s. Once I get new tires I’ll probably be switching to bolt on spacers to bring the wheels out even more since I have fender flares
dernals
I had a 2017 z71 1500 and I hated the wheels/tires it came with but I lucked out and I was given a pair of OEM wheels with street tires. I put those on and I removed the rear block instead of doing the level up front. It looked so good and I got tons of compliments but a few people wanted to talk shit because of the z71 badge. At the end of the day I loved the way it looked and it suited my needs perfectly. I wasn't really taking that thing off road anyway as I had other vehicles better suited for that.
jordan11
ordered the belltech shocks. Was able to get the front done this week. I have a 4wd RST 3.0 Diesel. The instructions said 2 spacers, which did just about nothing for lowering. Went to one small spacer for the front. Also installed 24" reps.
Picture with tools is with instructions for 2 spacers.
jordan11
I forget the measurements. But only one small ring on the front shock and one larger (iirc) one on the rear.
Phillysays
Pictures of BellTech coilovers installed. Lowered approx 3 inches up front and 4.0 inches in the rear. Rides firm, but handles like it’s on rails. Part #15009 front and part #15013 for the rear. Super easy install overall, and nice to not have to mess with OEM strut/springs. Just rip and replace with the coilovers.
CMoore711
The 21+ models can benefit from some lower offset wheels.
Even those 24” x 10” Vossen’s with a +25 offset are pretty tucked.
The wheel wells are definitely larger in diameter and wider on the 21+.
arcticcat522
First post....about 3.5 front, 4 in the read. 2" drop spindles and lowering struts in the fromt, lowering struts in the rear. ...also to anyone lowering....the front passenger side, remove the bolt on the rear battery tray. If you don't your tire will get tore up from it hitting. Could use some spacers, but I still like it. Also, just took the grinder to the little stop on the lower a arm to get some better turning radius. Helped alot!!
BadDaddy2003
