Is it normal for temps to rise during a long idle?
AN292
It was like 90-95 today. I had the AC on after a drive and was sitting in my car for about 20-30 minutes waiting for a friend. AC on.
After 20-30 minutes the AC was a little warmer and my gauge barely started creeping past 210.
I went around the block and brought it back down, AC cooled off again. Coolant is full, no leaks
Is this normal based on the amount of time I was sitting there not moving?
Truck has a new fan clutch (a week old), water pump (1.5 years), thermostat (1.5 years), radiator (1 month), and orange coolant (1 month)
Every single part is OEM.
rockola1971
Indiana (formerly IL)
Not unusual for temp to rise while sitting at idle in that high of outside temps. Especially if the vehicle is sitting on Asphalt. Im not sure what a "little warmer" means on the a/c so I cant speculate. You should see atleast a 20 delta between the outside temp and the air coming from the vents temp(A/C). How do you know the refrigerant is full and no leaks? Do you have pressure readings?
AN292
AN292
As far as no leaks I was refrrring to the coolant from the reservoir, water pump, hoses, thermostat. I don’t have pressure readings. But yeah I was on asphalt and I guess the idling fan doesn’t push enough air on a hot day just sitting around for that long. I took a trip around the block at maybe 10-15 mph and that did it
I'd say that's normal with a clutch fan, which is why some do the electric fan conversion. Could also be that some aftermarket fan clutches don't work as good as the OE ones. You could try to idle it faster for a few minutes to see if the temps come down.
I assume the fan shroud got put back in its proper place.
GMT800 2005 Tahoe Z71
Navy Supporting Member
OEM parts is a good call. I would check the air flow across the radiator and anything in front of it. If you live in remote or field areas you can have a lot of dirt/debris in there that needs blown out. If can, remove the upper cover and reach in there with a long bent at end tube and air pressure from backside will help blow out. I can really tell the difference from my 02 fan clutch rig and my 05 electric fans rig. See my recent trip info in my Build thread. I was in 100+ degrees temps and high humidity and accel up passes and temp never climbed over 200 degrees.
mattbta
Frisco, TX
I just had my AC repaired yesterday -- when moving it hits 38* out of the vent. I sat in a Floor & Decor parking lot today waiting on the boneheads with the fork lift to get a vanity we ordered for about 15 minutes. Outside temp read 108* on the mirror. Vent temps hit 60*. Coolant was steady, but would rise if we waited any longer. Clutch fan is OEM only a year old. I've got electric fans waiting to go in when I can get motivated to work on it....that should help the AC and probably even the idle or low speed coolant temps.
A couple years back, we were in Hill Country, TX. Drove through one of those wildlife nature preserves. Slow moving lines, 110* ambient. I knew my cooling system at the time was weak and I watched it creep up. - had to rev it a few times to help it out. I'd be curious with e-fans and my new WP how it would do.
Sometimes, it's just too damned hot for anything.
RAMurphy
Bob
Military
S. Maryland
Absolutely normal. One of the main reasons I installed high performance electric fans and a high performance alternator on my 2002 Tahoe. I'm getting old and I need to stay cool.
As noted in my build thread, I did all OE water pump, thermostat, high output alternator, radiator, hoses, belts and tensioners and idlers, coolant reservoir and verified correct electric fans operation and replaced all related sensors and relays. Was any of it bad, no.... I replaced because I am keeping the rig and did not want to piece meal any of it. I have replaced many complete SYSTEMS on my rig. The a/c, front and rear, already worked great with cold temps. Still does and the 5500+ trip I just took explains how I put all systems to their limits in intense heat conditions. I hate "system works good enough".
rockola1971
Just an FYI concerning the AC outlet temps. With a correctly charged system and all else in the system working fine you should see ATLEAST 20 degree temp drop below the outside ambient temp. The key word is atleast. It might be right on the money or usually even much lower. But the temp coming out of your vent is VERY dependent on the outside ambient temp. The higher the temp gets outside the higher the temp will be coming out of your AC vents. Thats just how the refrigeration cycle is designed at the mercy of the ambient temp. You could say that any AC refrigeration/cooling looses efficiency as the temp goes up outside(where the condenser is located).
I also believe that the higher the humidity, the harder the system works to keep up with keeping the inside cooler. High desert temps are easier on the system than high humidity temps in say....Louisiana. Correct?
rockola1971
Yes, correct. Humidity carries heat. All air conditioners are dehumidifiers. Your refrigerator, deep freezer, central air, auto ac, window ac, etc.....all dehumidifiers. Thats how A/C removes heat by evaporating it on the evaporator. The refrigerant absorbs the heat to be carried out to your condenser and the humidity (water) is drained from below your evaporator. On a automobile thats why there is a water puddle below your vehicle when the a/c is on. In your home central air thats why there is a water drain line running to a drain, drain pipe, etc from the bottom side of your evaporator. In your fridge and deep freezer the humidity is recycled to your condenser via a drain pan that your condenser coil bottom side sits in and is actually used to lower the temp (pressure) of the high side in your condenser which actually makes it more efficient. This would be the same as you going outside to your home central air condenser unit and spraying it with cold water out of your garden hose. Remember the lower the outside temp the colder your vent temps(supply air) will be. This is because the condenser is cooled by the outside air and by adding cold water from the garden hose across the condenser coils will cause the refrigerant to reject more heat readily to the atmosphere and lower the pressure of the condenser refrigerant that is on its way back to the evaporator after passing through the condenser coil. The lower the high side pressure becomes before it gets to the evaporator the lower the temp of supply air will be.
afpj
02 Yukon 4x4 ff. 118 today on pavement, high desert southwest. After fully warmed up, backed up at a light down the road , Idle for 5 minutes and coolant temp via torque pro hit 215 before the light turn green & off I went. The temp gauge on the instrument cluster doesn't go up above 205 ish. Just left the AC on 80 and the AC was cooling pretty nicely even at idle. Have a heavy duty fan clutch. It was whirring like a big rig when I hit the gas. Thankfully, AC was performing much better than 118 - 20 which equals 98°. Well, at least it felt that way.
blueinkd
My truck idles for long periods daily during this texas heat and no changes on temp at idle. I will sit in a spot close to an hour idling and both front/rear ac going. I do have new AC Delco water, pump, radiator, thermostat, 50/50 dexcool mix and all new hoses under the hood. Been 100* degrees outside this month. I can definitely hear the EFan on high speed as well at times.
After driving for for about 30 mins or so, the AC will keep nicely cold even when I park and idle. Mind you recirculation mode has to be on as well to allow the already cooler air inside the cab to flow past the evap core. No sense in continuing to cool down the outside air
The ac in these trucks tends to not be so cold if you do much idling in real hot weather, e-fans or clutch fans. The engine temp shouldn’t rise though, at least mine never does but I did the e-fan conversion on my 02 so yours may be different with the clutch.
I am on the other side with this when I had my 00 5.3 with a fan clutch as long as everything was good I could idle for hours in 115 deg ac on, temp never budged
I had that vehicle for almost 14 years, when the temp would start to climb it was because of the radiator, put in a new radiator and back to normal
so what I started doing was a annual flush with citric acid, this kept the system clean and flowing good.
my speculation with your issue is the fan clutch is not working properly or the radiator does not have good flow, regardless of age.
my 2012 does not budge either, it can idle all day ac cranked, 100+
rockola1971
The temperature Delta is atleast 20deg. Usually is it is much closer to 40deg unless refrigerant is low (leak), condenser is dirty as heck or something else wrong in the system.
afpj
When you guys are saying the coolant temp never budges sitting at idle, are you referring to the coolant temp on the cluster gauge or an independent source like torque pro or Scan gauge? My cluster gauge doesn't ever budge above 205 warmed up... just under the 210 mark, Even when torque pro was reading 215.
I mean, you’re talking a 5-7 degree difference? I just use the cluster gauge. It’s fine as far as comparing how hot the engine is on a cool day as opposed to a hot day. It might not be perfectly accurate but we are talking comparison from one day to another. I have seen my engine get hot -and it definitely registered on the gauge- when it’s lost coolant so I know it does work.
Electrician
To help put it in perspective: Im using an OBDLink mx+ with their app linked to my head unit so I can read all my sensors basically. Including air intake temperature, which I keep a gauge for on my screen to monitor. Left my house the other morning: 85 degrees air intake temp cruising 60mph. Bit later... get to a long traffic light, a/c running... temps climbing to 130! A few days ago, 2:30ish in the afternoon, got in my truck to leave work, started up to cool me off, few minutes air intake temp was 190!!!
Doesn't take long at all for your engine to start sucking in oven hot air when you sit
JasonW4141
