OEM Trailer Brake controller
kurt24
So I have seen some other threads but others don't seem to fit in my situation. We have a 2021 Tahoe that did not have the trailer brake controller installed. However, I can clearly see the harness in the proper location, ready to be added. I purchased the OEM brake controller online and have 2 questions. Do I need to buy a new trim piece with an opening for the brake controller? Should it just be plug and play or do I need to have Chevy program it? A lot of others seem to not have the harness in place but I do... So this should be simple..... Right?
I seem to remember a guy with a pickup truck of your generation saying it was plug and play. Double check with a search over at the GM-Trucks forum.
Stbentoak
It will be plug and play for a purchased OEM brake controller functionally, but it won’t necessarily have all the software/camera features that you get with Max Tow.
DenaliCountry
When I was doing the research on whether or not to buy a MAX Tow package Yukon I spent a lot of time researching this. Everything I read said you couldn't add the factory controller because that controller is integrated via software into the dash so you can see the trailer gain, etc on the dashboard and without that software you would have no idea what your gain control was set at. I was told you needed an aftermarket controller that mounts near the radio similar to the one pictured below. This one is offered on the GM website for adding on a brake controller. I'd call the a dealer and see what they say, but based on the month+ of research I did, the controller you have will not function properly. Aftermarket brake controllers should be plug and play like this one but are not integrated into the DIC which is where the factory brake controller is going to have problems without the software.
Edit: May be worth just going under the dash and plugging it to see what pops up on the DIC when its connected.
K
kurt24
I called 3 dealers. 1 told me it may need to be programmed but he didn't sound sir of what I was even talking about. The other 2 said plug and play. Well I plugged it in today and nothing seems to be working... No lights on the controller and nothing pops up on the display... Seems less plug and play than desired...
WalleyeMikeIII
Sunny and Snowy Minnesota
May need a fuse installed? Possibly a reprogram? Not sure..check to see if fuse 63 in the underhood fuse block is installed:
Plug your VIN in at the link above and see if there is a programming option.
DenaliCountry
I spoke with my dealer at length about this and you will need an aftermarket controller unfortunately. Unless they have come out with a way to integrate the controller after the fact (as of February 2022 they couldn't). It sucks, that's why I passed on a few different incoming Denali's and waited for one with Max Tow.
K
kurt24
Seems nuts. The damn wires and harness are right there. I would pay for them to program... The most annoying part is I spent another hour on the phone talking to my 3 closest dealers and no one gives me a straight answer. The closest dealer to me said "Well our service tech manager isn't going to have a conversation with you and give information for free. That's how we make money." I said "I'm just trying to find out if this is even possible! If it is then I will bring it in for you to do. I'm not looking for him to spend an hour facetiming with me and walking me through it.." He proceeded to tell me that the tech won't talk to me. I hung up
topaq
It's my understanding that the harnesses are the same whether you have the MAX Tow package with the integrated trailer brake controller or not. Just not connected to anything. Without the MAX Tow package you don't get the ITB controller any of the other needed components. Everything I also have read indicates that an aftermarket brake controller is your only option.
26AT4
