Sooooooo, I bought a PPV ...
992dr
Eastern N.C.
:lol:
I would love to go mirrorless and upgrade all my gear, but all my money is going into my Z06.
Good gawd, wowza they are shnazzy. I don't blame yah haha, love your ZO6 it's a pretty bad ass car.
Might as well show it off, you know photography talk nsfw talk tingly feeling talk :)
PPV12HOE
NC
Totally forgot one of the main reasons I bumped this thread. :lol:
Tailgate stopped working suddenly, just when I needed it to work most. Got time to dig into it the next day, found the glass in the rear hatch worked fine, so I knew the harness had power. I drilled the embossed "spot" on the inside for panel for the hatch, and manually unlocked the rear tailgate without an issue. Didnt even feel like busting out the multimeter, so ordered a new button for the tailgate release (all over eBay and Amazon for $15). Slapped it in and worked perfectly.
IIRC, this is the only the third problem I've had. TPS sensor failure, water pump, now the tailgate release button. Think I'm around 265k miles now? Still have zero regrets, still daily driving, still have the trainhorns, and still have people panic slam on brakes when they see me. Enjoying this thing until it literally falls apart.
What you didn't save the old one out of the old hatch...?
RichardCranium
RichardCranium
Mebane, North Carolina
ChunkePPV
Finally found time to get the new clock spring and the steering wheel in. Also cut out the dash trim for my DIC switch and had the cutting wheel break, pretty much ruined an otherwise perfect cut for the trim. It's beyond salvageable, without gluing on some sort of plastic piece on the face of the trim. It'll be easier to just buy the dash trim.
View attachment 182724 View attachment 182725 View attachment 182726 View attachment 182727
Hey long time, mr cranium, what part no was this steering wheel?
RichardCranium
RichardCranium
Still have the "old" Alpine iLX-650, decided to hold off on a replacement since I drive the Tahoe a lot less. Finally bought the Moto AA adapter, holy crap it's worth it. Only driven once with it so far but it's certainly worth the $60-70.
Is there an LED version of those projectors you have? Or, I guess what I should ask is if there's an LED bulb for them that works as good in them as HID.
There's a set of these not far from me that look to be in like-new condition for $100. I've never been a fan of such flashy eBay parts, but I like the squareish lights and the LED C-bar isn't such a turn-off. The projectors in these usually suck. But, for $100, I was considering getting them and retrofitting good projectors. I realize it'd be a lot more work than retrofitting stock housings like you did. It looks like I might have to shave the new lens to have flat top and bottom.
RichardCranium
RichardCranium
With Morimoto, you surely can retrofit either way (HID, LED, etc). If I did it again, I'd probably go with their top shelf LED housing to retrofit. I'm still super happy with the HID, so no plans to change.
I had a set of a similar style aftermarket headlights, should be in this thread somewhere. Actually think I made a separate thread. Anyways, they didn't look bad on truck, but even with a quality LED, the output wasn't near my expectation. Still better than stock.
If you've got the time, tools, and mechanical inclination, I'd absolutely recommend a true housing retrofit. It surely is worth what you put into it, which isn't bad at all really. Also that is coming from someone (me) who turned wrenches for 15+ years for a living.
Geoffsfas10
St. Louis
i really like those styles with the C bar running lights, actually thinkin about ordering a set and redoing my retrofit into some. these headlights are pretty easy to do once you get them popped open, you'd just need to make a bracket to support the new projector but in the talks I had with Lightwerkz, those are pretty easy to work with
I'll definitely be retrofitting a good quality projector. It's just a matter of deciding which route to take: Putting the Mini H1 8.0 in stock housings which is the simplest, fastest and clean... but also a little boring. Or, putting in the extra work to put the 8.0 in some fancier housings.
Geoffsfas10
St. Louis
If you do the fancier housings, you might end up with more room inside the actual headlamp assembly between the rear of it and the front cover, you could potentially fit the entire MLED projector, and those just clip into the factory wiring harness, no need for relays and such.
Good point! I'll have to compare the size of that to the Mini H1 8.0.
I'm taking it that those MLED projectors are way better than just using an H1-sized LED instead of HID in the Mini 8.0.
Geoffsfas10
St. Louis
infinitely!
The projector has a chipset and board built into them, vs a bulb thats dropped in. they are designed 100% as self contained LEDs
RichardCranium
RichardCranium
WhachuTalkinBoutLouis?
I was wondering what 22s you were talking about! What's your story on them transport wheels?
Scored them on eBay, used on one transport and have been sitting. Taking them to get powdercoated Monday, gloss black. I've got Kumho's ready to go on.
BadDaddy2003
