Illuminated front Glowtie
hdrolling
Grays Creek NC
After reading the install Instruction for the front illuminated bowtie (glowtie) I figured it had to be easier than removing the front grill and drivers headlight.
It was, the plug can be reached from the driver side wheel well easily, and then the wiring can be installed under the black plastic trim piece covering the radiator. Pretty easy install.
SSGUNNER
Nice will need to look into trying this one.
Veecee18
Lies, on it being easy. Not easy. Prolly wasn’t easy for you either but people just say those things to look the part
hdrolling
hdrolling
Grays Creek NC
Sorry but what part wasn't easy? You remove the screws holding on the wheel well liner and then just unplug the harness from the light and plug this inline. If you found that hard you might want to stick to paying someone. So far I have installed the illuminated door sills, illuminated bow tie, bowtie flood lights, Gm Performance exhaust, cold air intake, a catch can and the rear cargo all weather liner. All with basic hand tools, no special cutting or welding needed to install any of this and it's all as simple as removing one part and installing another in it's place. Some people are just not mechanically inclined, no shame in that.
ljn21
Have a link for the catch can you installed?
SSGUNNER
Here is the one I installed and some pics:
MSTI
Savannah
I just tried your method of install and everything was as you said it was except I could not get the light connector removed. I did pull the red tab out but at the angle my hand was, I couldn't get enough torque to pull it. Fortunately, that was my starting point so the original bowtie is still intact. Any tips? I really would like to do this without removing the grill, etc.
Veecee18
My hands were too big. Had to get someone with smaller hands to remove the wiring from the headlight and reinstall the glow tie wire. Wasn’t fun but yes got the job done and I thank you for that. But not easy with my own hands. On that note I apologize for coming off like that. May I ask you which intake brand did you go with ? I keep looking at cold air inductions but have been hesitant because I’ve heard that originally Chevy halted all intake sales because something wrong was happening to the computer with their own Chevy intakes. Not sure the specifics. Just know when I wanted to order one, they shot it down.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What are those clip on things for the nylon ties? I like those.
MSTI
Savannah
I tried again today and got it to pop lose with a flat screwdriver but no amount of pulling with my fingers was going to free it. After that it was easy and took maybe about an hour. Everything works and thanks again for the write up!
ts007
How did u remove old bow tie and put on new glow tie ?
LDJ87
Anyone has a link for the illuminated bow tie? Should I buy it directly from Chevy? TIA
Durobans
