What are you doing about tires on 22” rims
SSGUNNER
Been a fan of the Toyo AT II and was hoping to find some ATIII’s but can’t seem to find any. Was thinking of using stock 22’s on my RST. I guess I’ll have to play the waiting game.
deezydo
I was wondering if anyone could recommend a beefier tire for the OEM 22x9. Trying to get some more meat around the wheel as well as fill in some of the wheel gap in the fender. I wanted to see if I could go this route or get a 1 or 2 inch drop and keep the all season tires in play. From what I've seen and researched, I could go for a 285/45-22 or 285/50-22 and use the original wheels.
DenaliCountry
I am planning on doing the G015 in this size on TE37s.
Any rubbing issues with your setup? Speedo error?
I don't think you will rub with stock rims but above is the speedo differential. Off by about 1MPH at 70 mph.
I would personally go with the 305/45/22 which is the same diameter as the stock tires just wider.
scottd
