Just Fishing
Can't fix stupid
Utah
Got my transmission cooling circuit completed over the weekend.
With both coolers active, there is a slight pressure decrease vs just running the single full flow -8an
Not much of one, but slight.
and only under load. :jester:
Close off the -8an circuit, and the pressure at idle raises by a few psi.
Running full flow for now, not about to mess up the engine break-in.
:yaoface2:
It was about 50 degrees this weekend, and the transmission temp ever went past 140f with both coolers running.
Can't wait to see how it does when it's 90 out. :beer:
Sparksalot
Bastrop County, Texas
Very likely a silly question but…
conversion of a 2wd to 4wd. Possible?
it seems the mechanical bits are likely bolt in. I’m curious if the transmission is the same or has a different tail housing to mate with a transfer case. When you get into the wiring harness is where if think it might get hairy?? Then programming. Lord only knows how much needs to be done. Or is that the total stumbling block?
transmission is different as far as I know, other than that it needs a transfer case, front diff, axles, 4x4 hubs. I would say probably a 4wd drive wiring harness, just guessing.
AWD might be easier than 4x4 but a 2WD chassis is different than a 4WD chassis for starters.
How so on the chassis?
They have different part numbers and different cross members. LT Holman said that it is easier to convert a 4x4 to AWD then to make a RWD into either standard, he said the mounts and holes are not there to bolt up the front differential. He was referring to GMT800s when he said this.
Not sure how one would go about integrating the 4WD system into the ECM, BCM, Cluster, etc. Lots of programming. I wonder if it could be kept manual, putting in the levers on the floor and can the front differential be converted to manual locking hubs?
I seem to think someone has done it before...
This guy is who I was thinking of but he went with a solid front axle. With his experience, he still might know and be worth asking.
Sparksalot
I think the electrical integration is going to be a killer.
I’ve thought for quite a while it wasn’t worth the brain damage required to attempt this. I’m sure in the long run I’ll come out ahead finding an SSV or Z71 for my future adventures.
RooTBeeRthe1st
I'll happily sell you my '14 ssv, to buy a '15-'20.
Lmao
Sparksalot
Rolled another grand in thecopcar. Note summer temp.
Monz11
Da Burg, Fl
Hey guys, I haven't been on much lately. Just wanted to let yall know, that I'm 6 weeks post op - rotator cuff revision, 2 anchors, coracoid grind down and bicep repair. No racing this year, but I did get a chance to attend TeamUSA week, which was both Tokyo & Beijing Olympic & Paralympic Athletes in DC. Biscuit got meet Joe and Doc *****!!
Hey guys, I haven't been on much lately. Just wanted to let yall know, that I'm 6 weeks post op - rotator cuff revision, 2 anchors, coracoid grind down and bicep repair. No racing this year, but I did get a chance to attend TeamUSA week, which was both Tokyo & Beijing Olympic & Paralympic Athletes in DC. Biscuit got meet Joe and Doc *****!!View attachment 371173View attachment 371174View attachment 371176View attachment 371177View attachment 371178
Cool! I thought you were just still busy with the move to NC. Tahoe still in FL?
JohanZ
