I’m back with an Esky this time
Snowbound
Snowbound
Jim
Chicagoland (Lockport)
I have a few minutes so I might as well update what happened Saturday.
I got a notification while I was at work that the automatic suspension control module was delivered. Soon as I got home I couldn’t wait to get that installed and programmed to see if it fixed my issue.
I first hooked up the scanner and checked the software and calibration identification numbers on the old unit.
Then I plugged the Tech2 into my laptop and went to the GM website and downloaded the only software I could find for this module. The calibration number was different but it was the only thing I found that was for this module.
After I downloaded the program I swapped the old ASCM for the new one. Then I removed the relay for the compressor because I wasn’t sure what it would do and I didn’t want the compressor to run while I was downloading the program. Not sure that it would have but just as a precaution I pulled relay.
This was the first time I’ve ever used the Tech2 to program a module and it was fairly easy but at the same time I was afraid I would brick this module.
After it did its programming I turned key off and plugged relay back in. Scanned the info on the module and it looked like it worked.
But the compressor didn’t run. I pulled the codes and it had one stored for compressor relay fault. I cleared the code and compressor ran.
I pulled up the data and all my ride height sensors looked good, same data as the old module anyway. Then I commanded compressor on and watched the air pressure sensor and it read 0 and started to rise. Awesome! Before I was seeing 189psi all the time no matter what I did.
So now I have no codes, service suspension light is off. no Air bag message, and now just waiting to get this rim repaired so I can drive this thing and see how them struts feel and also can’t wait to hear no rattle in rear from that bad sway bar end link. So glad this is fixed and kicking myself for not doing it sooner but I really haven’t had the time.
Snowbound
Snowbound
Jim
I have some catching up to do and also some updating to do but I’m treating the most common rust spots today on my vehicles and I don’t believe I’ve ever shared this and what I do so I figured I’d throw it out there.
Starting with the doors, the bottom and back side of the door skins are prone to collect moisture and debris where the outer door is folded around the inner door. It’s always best to remove the door panel and clean out anything that has collected in there while it’s dry. Doesn’t have to be perfect but a blow gun to loosen it up followed by a vacuum is the way I do it. I don’t have any pics of that because today I’m only treating it do to limited time.
There are a few different things you can use, ATF works great because it has a lot of detergents in it but it does leave a smell for a few weeks. Petroleum jelly warmed to a liquid is also a good treatment but takes a little longer. You can melt it in microwave or by using a heat gun in a metal bowl or container. What I find easiest and cheap is mineral oil. You can pick up a gallon for under $20 and it doesn’t need to be heated or have any smell. Baby oil works for this too.
The syringe I got off Amazon a while back, they’re cheap. Like $6 for a pack of 3.
Then I take a piece of 3/16” brake tubing and cut it so it reaches the bottom of the door thru the window channel and leave some extra so I can do all my vehicles and also reach in from the rear after removing brake light from my truck and get to the top of wheel arch.
Just roll down the windows and feed the brake tubing in between window and seal. For the back of the door I like to start high and allow the oil to run down the seam. Then fill up the bottom of the door by moving the tubing to 3 different places along bottom. I use about 100ml of oil for each door and attach to brake tubing with a piece of 1/4” hose. Just put some towels and drain pain down to catch the oil as it drips out.
I’ll go in from under the hood into the back of each fender and use about 60ml to treat the drains. Remove sill plates from inside doors and put oil into holes to get it inside rockers. I usually hit that the hardest. Couple different ways to get above rear wheel wells but you can get to it from removing brake lights. May have to put a slight bend on tubing to get the oil where you want it. Go crazy with it and get everything and anything coated. The more the merrier. I usually do this every 2 years. Last couple years I’ve been slacking so I’m really going to town this time.
Just sharing something easy and cheap to help others try to keep their vehicles and investments clean and as rust free as we can keep them.
I’ll get back to the group later and give some updates on what else I’ve been doing. Hope everyone is safe and healthy.
Mine are probably due to be lubed as well
I've been brushing on Por 15 on the rust spots on my van. Thankfully it's dark green and the black Por 15 doesn't stick out too much. I like your idea. Doesn't the oil on the inside attract dirt/dust to it?
Snowbound
Snowbound
Jim
That dirt and dust is sticking to the damp metal without this treatment anyhow. The benefit of having the creases filled with oil is it will not allow moisture to sit in there and rust away the metal. The issue with only using POR is if the metal was not treated prior to using the coating, it’s just traps the moisture and it rots from the inside out. POR is a great product but it gets hard and can crack. Then moisture gets behind it and you’ll see the paint flake off exposing the rust. You should clean the area the best you can with a wire brush and some scotch brite pads, rinse it down and/or blow it out so it’s dry, use an etching metal prep or rust convertor and then coat with POR. The paint is for cosmetics and I would still pour some sort of treatment inside because the oil will get where the POR can’t or didn’t. And also the oil doesn’t harden so air and water won’t get behind it to contact the metal. That’s just my thought process and it’s a cheap and easy way to help preserve those seams. I’ve seen where guys have tried to seam seal the inside of the doors but if there’s any void or even the smallest pinholes that moisture will still get in there and do damage. You also run the risk of sealing up the drains or allowing water to sit because it’s built up too high in spots. I don’t know if my method is the cure-all but I can’t see how it hurts anything either.
Snowbound
Snowbound
Jim
Back to where I left off on this rig. The place that was repairing that small crack and powder coating the wheel for me kept pushing me off because they were busy and telling me it was 2 weeks before they could get to my rim. I said screw it and had to put the wheel back on and give her the vehicle back. I’m losing about 2lbs every other day so I’ve been having to check and fill the tire until they call and tell me to bring it in. I almost think they have forgotten about me but I’ve been busy so I haven’t called them either. I need to do that.
But with wheels on, tire pressures checked I’m sitting at 36-1/2” to wheel well. I’ll check it again in a few weeks and see if it has settled any from the new springs settling in.
I wouldn’t say it rides any better or any worse. I wasn’t expecting a miracle but I can’t positively say the old struts were bad. They didn’t leak, but I’ve always thought this thing should ride better than it does. Idk, maybe my expectations are too high for a heavy SUV. It doesn’t “float” either or have body roll so I guess it’s as good as it should be. The new rear sway bar end link and bushing feel better though. I’m still waiting for my electronic struts.
Snowbound
Snowbound
Jim
She took out the drivers side mirror on the garage door a while ago and I finally got around to changing that out. Started by removing the top of the housing and then you can get in there with a long skinny flat blade screw driver to release the tabs that hold the mirror to the motor plate.
The replacement mirror is heated and has turn signal but it didn’t come with the light sensor for it he autodim. Kinda made me mad because it said it was a direct replacement.
Another thing you can see is the original has a trim ring around glass where the replacement does not. I was close to returning the replacement and ordering an OEM.
Snowbound
Snowbound
Jim
Then I found this and said, I’ll live with what I have.
I pulled off that trim ring to see if I could transfer it but I couldn’t. Probably could have glued it on but what’s the point.
Here you can see that sensor for the auto dim feature. I would like to keep it factory but $300 for a mirror, it’ll have to wait.
I didn’t get a picture of the finished product but it’s pretty self explanatory, it’s just a mirror. Turn signal works fine and it looks like factory so I guess I’m satisfied with the outcome. She is.
Maybe junkyard will have the whole mirror cheaper?
Snowbound
Snowbound
Jim
That’s definitely an option. I’ll have to call around or go on carpart dot com. Those motors aren’t cheap either so a complete used mirror might be a buck fity. And I need a motor for the passenger side because it won’t power fold. Maybe they are the same for both sides and I can kill 2 birds with 1 stone.
Snowbound
Snowbound
Jim
I’ve had a lot going on as usual. This Esky is about to get retired. She’s ready for a new vehicle and I’ve been fighting with an O2 sensor. Changed it and still was getting bad signals and found the wiring harness rubbed on the front driveshaft so I repaired that and it was fine for a few months but then came back. Replaced the sensor and it still comes and goes. It’s the post cat sensor and I think it’s a bad cat that’s causing my issues now. Still might eliminate the cats.
Then her amp went out and had no sound for anything. Chimes, signals and radio were gone. A new old stock amp is $700 so I found one used for $200 from a low mileage crashed truck. Still a pain in the rear to change because it’s under the center console.
I did find what burnt on hers but I’m not gonna repair it, the new one is in and working so it is what it is.
Snowbound
Snowbound
Jim
My son Jack joined the Air Force in April. His ship date was set for July 16th but there was an issue with the job he wanted in cyber security so they pushed it. Didn’t work out so great for me because I booked airfare, hotel and rental car for the first week of September when he would have graduated and couldn’t get my money back but I did get to change the flight. We also booked an Airbnb for the week of September 18 with friends but then Jack left 2 weeks later which puts his graduation the same week we planned on going to Knoxville so I lost that deposit and rebooked for San Antonio for his graduation. It was an emotional rollercoaster saying goodbye to my son who will be not only a man when I see him next but an Airman.
Friends just stopped by, I’ll finish when they leave.
Snowbound
Snowbound
Jim
Jess and I took Julianna to see Hardy last month. 10 years old and her first concert. We had good seats and the concert was great.
Mulder is getting big. We’re going thru the process of breeding him. He’s already been going to training 2x week for the last 8 months so he does really good with commands.
I also put up a pool for Julianna this summer. She is such a water bug and it’s hard to get her out of it. Jess and I are always there next to her or in with her while she’s in it even though she’s had swimming lessons and is a good swimmer. We refuse to be a statistic.
It’s coming down this fall. I might even have to repair the yard because it looks like we’re moving in the next year. The school didn’t work out the last couple years and now I have her enrolled in a different school that’s not in our district and tuition is crazy so it’s easier to move than it is to keep paying tuition considering I haven’t built my garage yet, I’ll find somewhere with more property and get a pole barn like I wanted.
We haven’t got a lot of time out on the bike this year like I hoped. Just working or having chores to do around the house has kept us from enjoying the bike.
Snowbound
Snowbound
Jim
I had to fix the clutch at the beginning of the season. It started with the clutch not fully disengaging at the end of last year. Shifting gears was harsh with first to second banging something awful. I thought it was just moisture in the hydraulic system. Changed fluid and even bought an aftermarket slave cylinder but that didn’t work. So then I rebuilt the master and same thing. Only left something in clutch but bike only had 14k miles. Took it apart and found a spring plate that was broke and it was getting wedged between fiction and steel disk not allowing the clutch to fully disengage. I could have replaced just one friction, one steel and that spring plate but instead I put a Barnett clutch in it. Shifts like butter again. Even easier than before due to that aftermarket slave cylinder.
Now for the best news. Had a main boss from the corporation come down to our plant and everyone thought it was going to be bad news to have him come down for one day. He ended up coming to the maintenance shop to seek me out. We had a sit down and he offered me a job in management as maintenance supervisor and assistant plant superintendent. They put a package together for me that pays me more money than what I make with my OT, a healthy sign-on bonus, I can make my own hours, salary based on 45hrs/wk, weekends off, 11 paid holidays and 240hrs vacation beside sick time and personal time. I couldn’t say no! I’m in the process of finishing up a few loose ends with the maintenance department while I can still put hands on and mid September after I come back from Jacks graduation I’ll no longer be blue collar. It’s gonna be a change of pace for me but it’s welcomed.
brice715
