Lifted/Leveled 2021 - Postem Up
JeffJSCG08
I thought I’d post mine up since I’ve asked a million questions on here. See if I could help someone else with questions. I ended up just doing the lower strut spacer (said it was 1.5”) with 18x9 method 316’s and 285/70/18 Nitto Ridge Grapplers. Zero rubbing but I’m very very close to the liners…I think I pushed the limits and barely got away with it.
Dude I love the look. I’m looking to get myself into 18” wheels with the same tire size as well. If I can ask, what is the offset that your wheels run? And with the bigger tire size how was the change in speedometer and MPG? Any additional road noise that come with the ridge grapplers? Thanks !
Jgrimberg1979
Yes definitely additional noise which should be expected with any AT MT Tires.
The Speedo is unaffected with 305 45 22.
olyelr
Elk Rapids, MI
He quoted the guy with 285/70/18’s, which is roughly a 33.7” tall tire, which is a bit taller than the factory 275/50/22 or 305/45/22’s. I would guess the speedo is slightly off without some way to reprogram it.
Jgrimberg1979
Yep it will be off, not sy but how much
LekGMC
Hey, thank you for the compliments. So I’m not 100% sure on the offset of the wheels (I think zero) but Method only makes one offset, in an 18” wheel with the lug pattern for our trucks. The speedometer is a slight bit off I think but nothing too drastic. I am going to ask the dealership to try to adjust it a little when they do the first free oil change soon. There is a tiny bit more road noise with the ridge grapplers but very very mild, especially for the super aggressive look. Any larger, all terrain tire would add some noise. I am very happy overall with it. I think I absolutely maxed out the tire size with the level lift and it’s super practical. My wife hasn’t said a thing about road noise or anything. She loves the beefy look of it too. I originally wanted to lift it more with larger tires, but I am glad I took this approach. Has the look I want but still very practical. Doesn’t throw off a lot and doesn’t suck much power from it either. Any larger tires, I think would affect those things much more. I’m flirting with that line but don’t think I crossed it. Best of luck to you with it. Hope I helped some and let me know if there’s any other things I can guide you with
R32driver
I can also comment on the ridge grapplers being rather quiet tires for how aggressive they look. I put on stock size 275/60/r20 on our yukon and the increase of noise from them is minimal but they completely changed the look of the vehicle. Performance is way better than the factory car tires it came with
flyfaster1
A new 2021 4x4 2021 High Country with 22s for wifes xmas present.. I wanted something a bit different but she wanted another one blacked out, minus the bronze on the front grill and bronze painted calipers. Now on a set of 20x9s, 3.5” lift and 285/60/20s. Full front, side mirrors and rear PPF, and finishing up the sides. Corsa sport with blacks tips sitting in the garage. Need to black out the side marker lights and rear, lower reflective lenses.
sanman28
View attachment 369426View attachment 369427A new 2021 4x4 2021 High Country with 22s for wifes xmas present.. I wanted something a bit different but she wanted another one blacked out, minus the bronze on the front grill and bronze painted calipers. Now on a set of 20x9s, 3.5” lift and 285/60/20s. Full front and rear PPF, and finishing up the sides. Corsa sport with blacks tips sitting in the garage. Need to black out the side marker lights and rear, lower reflective lenses.
Bad ass.
olyelr
Elk Rapids, MI
NICE!!!!
What technique(s) did you use for blacking out the chrome?
flyfaster1
NICE!!!!
Wrapped gloss black. That way it's easy to replace if/when chipped or any piece starts to peel. Then, bought some over priced OEM black emblems.
RCM6
2021 Tahoe LT 4WD
1" Motofab "Level"
285/60R20 Toyo AT3's on the stock wheel
No spacers, no rubbing, no trimming
I wanted to go with the 3" Readylift SST kit and a little bigger tire, but the wife needs to still be able to get into parking garages. We really like how it came out.
flyfaster1
2021 Tahoe LT 4WD
1" Motofab "Level"
Looks really clean! I was thinking the same thing after measuring about 6 times in our own garage, and then just said screw it… guess she’ll be parking outside lol. I think we’ve got a couple inches to spare. Hopefully it still gets in parking garages.
Yukonxl21
View attachment 369426View attachment 369427A new 2021 4x4 2021 High Country with 22s for wifes xmas present.. I wanted something a bit different but she wanted another one blacked out, minus the bronze on the front grill and bronze painted calipers. Now on a set of 20x9s, 3.5” lift and 285/60/20s. Full front, side mirrors and rear PPF, and finishing up the sides. Corsa sport with blacks tips sitting in the garage. Need to black out the side marker lights and rear, lower reflective lenses.
Which wheel are those?
Ckarr
Alright. I’ve stalked this page for years and never actually posted any pics of our previous leveled vehicles. Looking back they were all white with black wheels. Not much changes I guess. Suspension maxx 2.5 front with new uca and 1.5 in the rear. Tires are 295/65/20 Toyo at2. Yes it’s tight, yes it required trimming and some more to be done this weekend. The grocery getter will definitely be set apart now.
sanman28
Nice. Maybe run a bora spacer?
Ckarr
I’m thinking maybe a one inch spacer would have it setting exactly like we like it. I’m going to measure this afternoon and make sure we can clear one
UAEdunes
Anyone ever tried 275/70R20? I can get some Michelin 275/70 R20 114T LTX Force
flyfaster1
Looks perfect!
enigmaspeed27
