INPUT ON TRANS PAN DROP, FILTER, GASKET & FLUID CHANGE
denalilex
philadelphia, pa
input on trans pan drop - complete fluid flush - filter, gasket & fluid change on high mileage vehicles ? (GMC YUKON DENALI 6.2L v8, 6L80)
when i was checking my fluids yesterday - trans looked a little high… siphoned some out & it was like black tar. i know sometimes it’s advised against to change these components on a high mileage vehicle. but i cannot in good faith put that fluid back in my truck. & so i’m stumped.
is this a legitimate concern with older GMs - or should i be good to drop the pan, clean it up & fill it up new?
i’ve purchased ACDELCO filter, filter seal & cork gasket kit as well as 3 gallons of ACDELCO dexron vi ATF for the task but would feel better with some input from some more seasoned of the members on here.
tia
*sorry if this was addressed before & i missed it*
St. Louis
Mileage?
Personally, I prefer clean fluid and would change it. You probably won't need the cork gasket though, the OE rubber gasket is usually reusable unless it's torn or currently leaking.
Oh and 3 gallons of fluid would just be enough to flush it all out, but you may need an extra quart or two to top it off to the correct level when done
donjetman
Do a full flush. 6L80e holds about 3 gals. Disconnect upper atf line on the radiator. Start it up, pump 1 gal out, shut it off, replenish the 1 gal with new Dexron VI thru the dip stick tube. Repeat 2 more times.
When you only drop the pan, you only get 6 qts out.
denalilex
denalilex
philadelphia, pa
Mileage?
hey - sorry for the late reply. had a few personal issues to take care of & trucks been on the back burner. have been driving my pickup that i use for work & i’ve got no more patience for ford so i’m back to my yuk.
in the past few weeks - i’ve managed to completely psyche myself out as a result of reading other’s threads.
my trucks got 290xxx on the dash … less than 50k of them are mine.. PO was - afaik - a corporate entity… i believe a rental or limousine service .. along those lines. so i believe, or presume, that it’d been serviced - at least to some degree - over the span of its years.
the fluid is BLACK. as for burnt….i don’t really recall what burnt tranny fluid smells like but from what i’m gathering - it’s one of those “you’ll know it if it is” type things. it has no sour/stale/rancid smell to it. & no particles floating around.
i siphoned what i could from the dipstick. i was able to remove about 6 quarts. if you hold the tubing up to the sunlight while pumping - you can still see the red hue to it. if that matters.
rough shift 2-3 but i think that’s a software tech2 calibration update issue. i have to get my hands on a tech2 but idk anyone with one rn. my truck has updates available via GM’s vin lookup tool. a few for my TCM. so i don’t think that is a trans issue hardware wise. 2-3 feels like you broke your neck but all other gears are smooth as butter.
i bought the sonnax pressure switch rebuild kit for the 6L80… so i have new seals. i’m throwing the 4 codes that - on the 6L80 - have typically signaled seal failure on the pressure switches.
with all that novel length information - i hope i’ve covered it all. sorry i’m really bad at cliffnoting my point.
with all that said - would you recommend/suggest a full flush? i would do so via the cooler line radiator outlet & hose barb + clear tubing. or could this fry the trans? i would think it’s still in good shape. the 6L80 just has some issues unrelated to just the fluid i think.
i also have lucas trans stabilizer.
or just stick with the fluid i’ve already taken out & continue with the new filter & gasket i have, the switch rebuild & top off the 6 quarts of fluid ?
sorry again this is so long ugh. thanks for your reply
denalilex
denalilex
philadelphia, pa
hahah!! i just typed this all out in a reply to the other comment on here. literally asking what you wrote here. haha. i’m gonna paste it here & just get a confirmation from you if you don’t mind. i just wanna give all the details in hopes of not speeding up the death of my trans lol… which, btw, i know that anything i do to my truck is 100000% my choosing & my own risk. & any advice is so appreciated…
Mileage?
Geotrash
Dave
Richmond, VA
The codes and the rough 2-3 shift tell me that the valve body has to come out to have the new check balls and other bits replaced on the bench with your kit. At that point, you'll be replacing the fluid anyway. In my opinion, new fluid alone isn't going to resolve the shifting problem you're having.
robgreg75
The first time I did the pan drop I installed a drain plug in it. The exhaust is in the way but if you have a light jack you can jack the exhaust down from the body and give just enough room to get the filter out.
denalilex
denalilex
philadelphia, pa
right - yes i agree. the new fluid is not / was never an attempt to fix my shift issues….the fluid change came about due to my checking all of my fluids & noticing just how DIRTY it is & i couldn’t in good faith drive my truck with THAT pumping through the trans & so it’s been parked while i got around to finally doing it. but over the last few weeks, i’ve been seeing very differing views on flushing / just pan drop & refill with new the 6 quarts you remove. but that brings me to the point of - i cannot drive this truck with that fluid running thru it & even changing 1/3 of the fluid still leaves me with 66.6% horrificly dirty fluid & that’s not a good percentage imo.
but ok thank you for this advice - the check balls weren’t something i thought of…. tbh, this is my first time working on a vehicle in this capacity … like actually getting into the mechanics of it. & not just your average oil change, brake pads, etc. i’ve fixed, repaired & cleared 52 of 56 codes since getting it. so i think i’m doing ok lol.
i have to pull the valve body to get to the tehcm / pressure switches anyway so i’m trying to address everything that’s needing it while i have it apart & on my bench.
the way i’m looking at it is - i have nothing to lose. this truck lived well beyond its expected service years & that makes me happy. anything that goes wrong i can learn from.
so any & all advice is more appreciated than i can say … yous are far more seasoned & experienced than me. & this site is cool as you’re all working with the same trucks as me.
denalilex
denalilex
philadelphia, pa
this is my plan! haha. it makes much more sense.
Geotrash
Dave
Richmond, VA
That's another good point. The weak link on these is the torque converter lockup clutch. And when it fails, it sends shrapnel through the transmission and cooler lines.
Meccanoble
Georgia
Yes I changed my tranny fluid twice and both times I had to bend exhaust a little so bottom pan can come out without damaging sensors/internals
denalilex
denalilex
philadelphia, pa
hey - any way you can point me in the way of where i can purchase a new set of check balls? i’m having some trouble tracking them down. i’m only coming across a full valve body overhaul kit that includes them with it & not just the check balls themselves.
thanks again !!!
denalilex
denalilex
philadelphia, pa
denalilex
denalilex
philadelphia, pa
thank you!! this is much appreciated. literally exactly what i’ve got ahead of me. thank you a bunch. this is the exact kit i purchased by sonnax!
Hello denalilex,
Here is what I went through doing pretty much the same thing on my 2013 Escalade:
https://www.tahoeyukonforum.com/thr...-flush-in-2013-escalade-esv-pic-heavy.130110/
Good Luck!
do you by any chance happen to recall the sonnax zip kit part number you ordered? i’m going to use your thread’s step by step process as my reference guide through this. i want to make sure i have whatever i could possibly need. you did your work on the same model.
thanks again.
denalilex
denalilex
philadelphia, pa
thanks again.
nvm disregard- i just read thru the whole thing. thank you again!
Geotrash
Dave
Richmond, VA
thanks again !!!
TollKeeper
Brighton, CO
I have seen guys that say unbolting the rear tranny mount, and then putting a jack on the tail of the tranny, will lift the tranny just enough to get the pan out clearing the exhaust. I have not done this, but have seen it done on a couple youtube videos.
Also, if you know for sure you are going to be replacing the tranny pan for one with a drain. I would drill a hole into the bottom of the old pan, and let it drain.. way less mess.
a1parrothead
