That's exactly what it's doing.
Do you mean the ratio?
The videos didn't show up for me until just now. The only odd noise I hear sounds like that exhaust leak.
With it on jack stands, you can lightly apply the brake until the wheels stop. While holding the brake, lightly apply throttle to get one side to break loose and spin. It's usually the right side that will spin. Maintain steady brake and throttle pedal pressure and listen for noises. Repeat in reverse.
Do you have G80 as an RPO code?
Walchit
I think Tonyrodz and I have about the same kind of luck. My dad always says " if it weren't for bad luck, I wouldn't have any at all!"
This is what it's doing as I'm power breaking it--applying throttle.
Making the noise everytime I'm going forward to reverse/reverse to forward then powerbraking it.
Could it possibly be the transfer case making that noise? Even tho the prop shaft for the 4wd isn't connected? It kind of sounds like that's where the noise might be coming from--from the front. I originally thought it was the trans.
Boneless_Bristian
During the holidays and on vacation one of neighbors is a mechanic. I had him change out the front sway bar bushings, all 4 control arms and most steering components. I used all oem GM parts. I painted all parts black prior to getting the work done. SUV rides like new now.
Where did you purchase the oem arms from and do you have the part number on hand by any chance?
ivin74
05 NBS Nali
Htown, Texas
I used the AC Delco 45D3174 or GM Genuine 19186776 for the front left lower $143.79 at RA then.
The AC Delco 45D3175 or GM Genuine 19186777 for the front right lower $145.79 at RA then.
GM Genuine 15864153 for both upper control arms. $203.79 ea., at RA then.
Sam Harris
Does anyone know if a JL4 equipped rearend is compatible with my non JL4 rear? I might have to replace the entire assembly, and a yard is telling me that it's compatible. Just want to make sure it'll swap on with no issues or modifications.
Phlipnstik
