04 suburban turn signal issue
Shatcher0428
Hey guys need a lifeline just replaced my turn signal switch on a 04 suburban, was the factory switch, so still having the same problem, turn signal on for the passenger side and tries to blink but doesn’t the driver side works perfect. Any suggestions?
adventurenali92
Big Bear Lake, ca
I had this exact same issue. My passenger side turn signal would stay dimly light, and then blink fast when engaged like a bulb was out. Driver side perfectly fine. Check the wiring on the front passenger turn signal harnesses. If there’s a wire somewhere that’s losing its coating, it’ll short out and cause this exact issue.
Shatcher0428
Shatcher0428
I read somewhere were it could be the turn signal flasher. Its a combination flasher, I have not ever seen anything like it. I sold flashers back in the day when I worked in parts, but it is definitely different. I order part number LM487 off of amazon for 54.00 autozone wanted 75.00. Hoping it will fix it. I will repost if it does.
Donal
Americus Georgia
So, still not working correctly?
veteran111
