2015 PPV/Help troubleshooting interior lights when opening up the doors.
Unssafe
I have owned this 15 tahoe ppv for about 6 months or so, when I first got the interior lights would come on with the brake pedal being pressed. There were lots of wire bundles under the center section of the dash, all cut but some crimped together. I cut the crimped together wires and it fixed the interior lights coming on with the brake pedal. I don't remember if the lights came on when the door was opened back then. I don't see any switches on/in the door jams. Where's a good place to start? I will try to get pictures posted of the wires.
Thanks
Thanks
the interior light switch control is on the roof in front of the mirror, on/door/off
other than that the sensor is inside the door lock actuator (built in)
U
Unssafe
That is the center console I built for it. I have the phoenix 12.1 screen in it as well. And that all works well. I'm getting ready to install the 360 degree camera in it and wanted to fix the issue of the interior lighting not coming on with the doors opening.
Thanks!
Fester513
Just bought a 2017 former police. Found that the connector for the over mirror lights was not connected. I think the cops had something else mounted there and after it was removed they stuck that center piece back up but never connected it. Hopefully you will be that lucky to be avle to just connect it.
Sparksalot
Bastrop County, Texas
Thanks
Sounds like the “disco lights” that a lot of the 2015s had. Mine too. You end up replacing the front 2 dome lights to solve it.
you can find more by searching this forum for disco lights.
wilburMN
