Show off your 2015-2020 lowered tahoes and yukons
Garen
Van nuys
looking for this set up. looks so awesome. please if you can put the details here. thank you!
Eddie Rivera
can you post what you ordered please.
This is exactly what I have on my suburban. If you have any other questions, feel free to message me.
Garen
Van nuys
you the best
Chevy*808*
Bigkevschopshop
Northside H-Town
Well following up after Chevy808 making everyone else look like a lift kit...
Got my drop installed.. I had the Eibach pro coils laying around that never were used on the 2012. Perfect fit for the 2015. Bought Belltech drop spindles up front . 2514 part number. Got the Belltech Shock extenders, and DJM sway bar relocator end links.
Notes, worse part of the job is the free travel mod. My plasma cutter failed a tip half way through second side, then my sawzall broke the blade, I had been holding off buying tips or blades till I could get my bulk pricing from a supplier but here we are so Finished with a death wheel and prayers. ALl in all not terrible.. Before and afters tell alot. I still think the rear autoride links may be a bit too long but Ill toy with that later.
Ride is very comparable, Maybe a bit tight in the rear due to autoride pumping up a bit. BUT handling is a very noticeable difference. Fuel mileage average up 1.5 mpg already. I was cruising 51 mph the other night at 33 mpg... INSANE...
The Eibach Pro coils are progressive rate coils, I had them in my 03 and they were very good. So far very pleased other than I want another 2" down already but for ride and what I use this for, I think staying here at 2/3 is about where it needs to be.
NOTE.... If you are over 6' tall and open the lift gate, be prepared to DUCK>>>>>> Shit hurts.
Before....
After
Before
After
17Betty
looks good. has anyone found and used a front lowering spring along with the Belltech 2" drop spindles? The reason I'm asking that I only got an inch in the from and really wanted a true 2//4 drop?
Twol8uluz
2018 Tahoe ls trim on a 2-3 beltech drop with 22" stock wheels/tires. Corsa exhaust (waiting for my Corsa cai).
Taking notes from you all for my Denali. Looking to go 2-3 or 4 myself. Like many of you, will have to fiddle with the magride to do it :rolleyes:
gat0r
DFW
belltech spindles for front
& springs in rear ;)
Any modifications to make magneride work? I’m in the same boat as @07Burb now that I see how inexpensive it is to lower. I’m considering it myself.
I know you have to mod the magneride sensor rods in the rear. I had issues with it on my '13 so curious to know if there are tips or tricks on it for the 15-20 rigs.
Tonyv__
Bucks county PA
With the spindles in the front you don’t have to modify the magneride because you don’t change the geometry of the suspension correct?
On the rear you do because the rear is sitting lower than the sensors are programmed to "allow". Front you don't have to fiddle with the sensors at all so that part is correct.
Tonyv__
Bucks county PA
Fun. I have to do ball joints soon which entails control arms etc… I might commit to some drop spindles while I’m in there and tell the wife it’s necessary…. You know inventory problems and Covid. Drop spindles is all I could find Then we can’t drop the front without the back.
That definitely would be a prime time to go ahead and do it for sure!
j_jerry79
