Just Fishing's 09 Tahoe Build thread
Just Fishing
Just Fishing
Can't fix stupid
Utah
I also did some reading and part number comparing for the transmission pump after reading up in my atsg manual for the 6l80.
they mentioned an issue where the older pump style used in December of 08 back caused a shift "flare" from 2-3.
I did have that shift flare, but i tuned it out by tweaking off going and oncoming pressures.
Cause was the sealing rings on the stator would rotate and caused some pressure loss.
Fix was to have these little "tabs" to keep the seal from rotating.
New stator style is required for that.
I found that Amazon has some pretty good prices on the hosing and stator.
But for the pump and rotor, you need to measure the housing, and then purchase the pump and rotor accordingly...
So, I have this on order,
Pump cover + stator
GM PN: 24248573
Pump body/Housing
GM PN: 24248031
Then I get the excitement of doing some measurements to confirm what pump and rotor I need.
This will also give me time to install all of the sonnax/transgo upgrades that I wish.
Just Fishing
Just Fishing
Can't fix stupid
Utah
A Dragoon or Thunderer by chance?
Nah, nothing that fancy.
Just an Army special, the patina is what really drew me in.
Looks its age, but not rusty or pitted and the colt logo and other marking are really clear.
I need to drop it off with my gunsmith for a look over + one of the cover plate screws is stuck, and I'm not wanting to strip it or break it.
There was also some misassemble of the crane retaining pin, looks like it hid a slight issue where I get some side-to-side slop of the cylinder lock.
Mistake, or purposely done to hide it? i dunno. :jester:
Otherwise, it's in great mechanical condition.
It was weird to see it at an antique thing, but that's probably the reason. :think:
m1949
LS364/450
MS Gulf
Might think about mounting magnetic strips on the wall. I had pegboard, but the peg bracket/holders kept coming loose and it seemed like I always needed another holder or a different type I got a new tool. Fixed that by screwing magnetic strips to wall studs. Now, when I need a tool I just pull it off the wall. When I'm through I just slap it back on the wall. And I got a couple extra strips so when I run out of space I can just mount another one.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
That is a worry.
I had a pretty small propane heater to start, but then when that died, I went with a forced air heater.
My garage door is insulated, I even insulated the little splits in the door since artic winds would cut right through them.
I also have the top and sides of the garage door sealed up nicely.
The garage itself is drywalled, but not really insulated.
I did add some wall insulation for the AC unit I have installed in the window, that wall got really hot in the summer, and it helped quite a bit.
but the propane heater i have is this one.
Even on the lowest setting, that propane heater is too much for my garage.
I have to run it for a little, and then turn it off or I start sweating.
On high, it heats my garage up to a nice toasty temperature in like 10 minutes or less.
I selected the 7500-watt heater after reading through some reviews.
Decided the 5,000-watt version was not enough.
It's pretty warm here right now, but @40 degrees it did great.
I found a fan helped a ton to circulate, and to keep the celling area cooler so the heater won't shut off so quickly.
Heater specs:
Can't wait till it gets cold again so I can give it a real test.
My shop is uninsulated but I have the trusses decked so in essence I heat a 24x30x10 foot space. I was out there Saturday and the high outside was ~12 degrees. Had it comfortable 60 degrees in the shop in about a half hour but it takes longer for the floor to warm up a a bit.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Floor kicks my butt in the cold.
I started keeping cardboard around.
Larger pieces the better.
For this project, I even started making larger orders on amazon.
Hoping for a single large box. :jester:
Summit racing sends out excellent cardboard.
Nice and thick. :boobs:
Amazon is ok, thinner but it still works.
Cardboard is very pleasant to lay on, warm, and it's easy to slide around on.
(Assuming the pieces are large enough, so I don't get caught on the edges)
:rocking:
:rocking:
I like indoor/outdoor carpet that I get at Home Depot. It’s cheap enough that when it gets oily or dirty I just buy another chunk.
:rocking:
If you go to your local supermarket and ask for some empty big boxes, they're usually happy to oblige.
George B
¯\_(ツ)_/¯
:rocking:
I use cardboard too.
pwtr02ss
Tennessee
:rocking:
Casey gets this foam backed material that they wrap bumper covers and things in. That stuff is excellent to lay on. Its like plastic on one side and foam on the other
Just Fishing
Just Fishing
Can't fix stupid
Utah
I have also used "work out"/yoga mats that my wife makes the unfortunate mistake of leaving in the garage.
Mosy i don't like anything that could hide oils and other fluids in.
Nothing worse than laying down and having the oils wick out onto you.
Cardboard seems to do pretty well, easy to tell when its soaked.
U haul stores sell boxes for a decent price.
I also saw my local homedepot (or was that lowes..) carrying decent sized boxes.
I have been keeping that in mind just in case i couldn't get enough decent sized cardboard... lol
My cold case radiator hooked me up with the last few pieces that i believe I'll need for what will hopefully be the last go around.
And that out door carpet is a pretty good idea.
I recall being able to get a decent sized sheet of it for like $40 ( grey color )
That was about 10 years ago.
When i did my first boat refurbishment.
A little 15ft starcraft, the type you drive from the front.
Tossed a 3cyl 65hp mercury on there, that thing really moved.
Second boat i went with vinyl flooring, specific for marine use.
The carpet held up well and cleaned easily.
But it was a fishing hook magnet.
I still use that home depot stuff to line trailer bunks.
Very tough stuff.
If I’m draining anything I keep the carpet back a ways so it doesn’t get any fluids on it. This is the stuff I get. It’s rubber backed, real thin. I have some bigger pieces rolled up but this one stays on my garage floor, ready for quick use.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Got my pump "cover" yesterday.
Located the transgo shift kit that i installed when i first got the old hoe.
Left over in that kit is an upgraded boost and pressure regulator valve.
Big part of that boost kit is a pressure relief valve in the end of it.
That's there to prevent a pressure run-away that causes a cracked 4-5-6 clutch drum.
That condition will cause the truck to drive fine, park.
But when you go back to drive it again, you have no drive and no reverse. :jester:
They also mention a slightly modified pressure regulator design that sits behind the boost valve.
That's to prevent a shift clunk that these units can exhibit.
The new boost valve was a very tight fit, i doubt there will be any leaks.
I'm sure this was designed for a used pump, and not a new one.
took some oil and careful well-oiled insertion to get it to seat completely.
then disassembled to clean once more... :emotions33:
It's also a steel valve vs the standard aluminum ones.
I suppose that's for a longer life...
I also have the Sonnax boost valve on hand.
I did some measuring between the stock boost, Sonnax, and Transgo.
I didn't see any size differences.
But the transgo did have a slightly heavier feeling spring.
Sonnax boost: https://www.sonnax.com/parts/5003-boost-valve-kit
Usually there is an increase in size to increase the pressure boost effect.
Interesting.
I guess they don't see a use for it, and it's all controlled by spring pressure.
The Sonnax also has a slight valve looking thing right down the middle.
Still waiting on my pump/bell housing cover, once i have that i'll snap some pictures.
Oh and the new pump has the updated seals that have anti rotational tabs.
Part of what's in the transgo kit is an upgrade for the first gen pump design.
Add's springs behind the seals to correct the issue without going to the newer design pump stator.
With the newer design pump stator, there are also some Orings behind the seals.
I didn't notice those o-rings when doing a dissemble of the pump for a good cleaning.
Hit the pump with some carb cleaner to break up the packing gunk, then rinsed off with break clean.
Then i saw those o-rings were swelling! :fc5716bd:Whoops!
Luckly the cover kit came with a spare set of pump seals and o-rings!
Just Fishing
Just Fishing
Can't fix stupid
Utah
Got a bunch done to the hoe over the weekend.
Exhaust is with the welder to have him install an extra O2 sensor bung.
I found some caking of oil all over the transfer case.
It also looks like the output shaft to driveshaft seal is starting to leak slightly.
I'm not sure if the nasty all over the transfer case is from that or not, but I'm leaning towards resealing the case while I have everything easy to get to.
This will also make it easy to replace that bushing in the case extension. ;)
I'm thinking it might be a good time to have U joints done @ 180k
But U-joints would be easy to do later on, so I'll make a decision later on it.
Part of this I needed to remove the front driveshaft from the tcase.
It has this seal on a slip joint...
Looked like I needed to snip a metal retainer for that seal in order to get it off.
but then I found a video on the subject, they showed how you can slowly pry that seal off of the shaft.
And it worked like a charm!!
With the transmission tilted down, I didn't have much of an issue getting to all of the bellhousing bolts from the underside.
Much easier than fiddling with a silly ratchet with the heads off.
Engine is ready to pull short of needing to reinstall the transmission crossmember and adding some sort of wooden spacer to level everything
(and to prevent the transmission from crashing to the ground)
And of course, i haven't yet removed the water pump
I didn't get a picture of this when i installed it, but this is my install of the transmission cooler line filter.
I used rivnuts in the frame to keep it cleaner and easy to remove later.
I'm planning to do the same for the power steering side.
For the transmission side, this will be AN fittings once I'm done.
Just Fishing
Just Fishing
Can't fix stupid
Utah
I picked up the Y last night, pictures soon.
Over the weekend i also yanked the fluid cooler lines.
Noted that the engine oil cooler side looks real close to 1/2 in, so i measured with my dial caliper.
Just slightly smaller.
So i grabbed one of the -8AN tube sleeves and gave it a little test fit.
Slightly looser, but i think it's tight enough to work as a support...
So I'm planning to reuse the stock oil cooler piping.
But I'll replace the flexible rubber sections with the nice braided SS line and AN fittings.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Oh and last night, i tried to use my abused second hand engine hoist to move the old 5.3 block off of the stand.
Looks like the hydraulic jack part leaked out most of it's fluid... lol
While i do have more, that ram has issues.
I decided fk it, and i went down to hf last night and picked up a new 8 ton jack for the hoist.
I decided to spring for the pneumatic version.
I figure this will make life so much easier when removing the engine on my own.
Gives me the ability to operate it from a distance.
And if needed, easy enough to lengthen the hose/control.
Just Fishing
Just Fishing
Can't fix stupid
Utah
I pulled the engine, heads still on.
I ended up removing the exhaust manifolds to ensure it didn't damage the AC.
Doing this on my own, so it's hard to watch everything.
With the crank pully off, it gave me plenty of room to clear the engine bay.
I also tried out this little thing i saw on youtube.
Apparently, the hood has a "service position"
You remove the spring-loaded bars on the side, and disconnect the gas filled hood prop.
And with the plastic hinge trim removed, the hood goes back.
Then some little hook little things are visible!
Just the right size to jam the bolts you removed from the spring struts.
Hood in service position!
Zoom in of the locking location.
Apparently in the NBS, this is actually a hole and it's threaded!
I heard after 2015, they did away with it all together...
Just Fishing
Just Fishing
Can't fix stupid
Utah
Engine sitting on the stand, It looked really huge with the pan still on.
Those valve cover spacers almost make it look like a big block IMO.
Just Fishing
Just Fishing
Can't fix stupid
Utah
And the Crank has been pulled in that image ^
I'm very happy to say that the Thrust bearing actually survived the last run!!
So, with the cooler bypassed = success!!
I had a mismatched set of main bearings, so i did have some metal.
I was expecting to see that coming from the rear bearing, but i didn't...
So anyways, engine is coming fully apart for cleaning and inspection.
I'm worried the cam bearings got some trash in there.
The only other thing that could match the color I see is the rod bushings.
One of those rod bushings I damaged when disassembling the engine due to all of the buildup.
I had asked that machine shop to freshen up the bushings, but they told it it was fine.
Since I don't trust them for shit now, I'm going to look over them carefully.
Maybe pick up a nice used set...
Adventure!!
I learned aspects of engine building that i never wanted to know... :jester:
worleytrev93
