2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Hope you get it broken loose man. I hate when things don't go as planned. Sometimes, its best to take a break for a bit and then bam, it works good.
That big boy milwaukee should do the trick...if not, put some more d*ck into it. You'll get er
If the Milwaukee doesn't do it then it's the first time it has been unsuccessful. I think she needs more juice and it will do it, I did spray it with creep oil so it should help.
pwtr02ss
Tennessee
The milwaukee would not break the manifold to y-pipe bolts loose on my avalanche. Had to get my buddy Casey over there on a 3' breaker bar to get them loose. I put everything I had on it. Took his big ass to get it done tho. It was on an extension though
pwtr02ss
Tennessee
I used the handle for my jack on the end of my 3’ Gear Wrench monster ratchet and put the truck in gear. I was running out of umpf and I’m 6’4” 215#. Worst case scenario I go rent a 1” two handed corded impact from some construction site.
Wow.
That mfr is on there
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
The new Comp Cams spring compressor came in as did the Elite timing set, can't wait to get back cracking at this thing.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
New spring tool worked like a charm except I bent 2 rocker bolts so I need to find new ones. I also got the crank bolt right off after yanking the fans and getting the impact on without a wobble joint.
Didn’t make much more progress other than cleaning up gasket surfaces and getting the timing set and oil pump on. I tried to remove and reuse the old valve seals but they were being stubborn so I just ordered new ones.
Are you using Vitron seals?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Been sick all week so I haven't made any progress but I did get my blackstone report from when I pulled the motor apart.
  • 04 TAHOE-220102.pdf
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
You don’t have Covid I hope?
Any ideas why the engine is wearing so much?
Ragged ole POS is the only thing I can think of.
Not covid but I already had it and was lucky to have very mild symptoms. I think I had the actual Flu (Yes it still exisits) I had body aches a mild temp and a throbbing headache.
Drewphil
