Leaking drivers side quarter glass on a Tahoe 2 door
Tbruz
Windham NH
1997 2 door Tahoe.
I have a leak that I think I've traced to the top seam of the drivers side rear quarter glass.
Called an auto glass company and they were not interested in trying to remove and reset that large side glass; claimed they were not willing to take the risk it wouldn't break on removal
Before I start calling around blindly, I'm wondering if anyone has any other suggestions or success/horror stories in re-setting this large glass panel.
Appreciate any input.
Thanks
Tbruz
Jason in DLH
Cheeseburger and Fries
MN
I’m just curious...is the window misaligned thereby letting water in? Or is the upper glass run damaged thereby letting water in? Or maybe a little of both?
T
Tbruz
Windham NH
To be clearer, this is the drivers side rear quarter glass on a two door, very large glass. So no misalignment of glass or damage to glass run is possible as its a fixed glass
Thinking I may have to remove the headliner to track it down.
Will try the flowable silicone along the upper edge to see if that helps.
Thanks
Tbruz
UPDATE: PPG glass company will remove, inspect and re-set the glass for $150. They are recommending having a replacement glass($350) on hand just n case of breakage during removal.
UPDATE 2: Re-set work completed on 2/26; new glass was used due to the rubber seal breaking off of the original glass. Total cost to me $100. There was a definite separation visible between the adhesive and the body. Tech was confident that was the source of the leak. After a full weekend of heavy rain in southern NH, I can report that the re-seal worked!
exp500
Tbruz- take a look at roofline side of gasket that should be laying flat on roof. If it is not that is your source. A wash out with brakekleen and a plastic nozzle then reseal with urethane when dry and press flat. Can clean up edges nice with a Small amount of mineral spirits on a rag.Fixed for $25. for 3-5 years.
T
Tbruz
Windham NH
exp500 - Thanks for the suggestion. That top gasket along the roofline is not where the watertight seal is created. While it may divert water away from the glass to body adhesive seal; Its more of a cosmetic gap "filler". Was easy to visualize today when the glass was out of the body opening.
iCajun
If you have a roof rack you might want to check in the area of the screws that hold it on.
Rudyr25
1997 2 door Tahoe.
Thanks
Tbruz
I also have a 99 two door with the same issue but on both sides. I took it to glass company and they basically told me the same thing to buy an extra glass incase of breakage. I'm gonna order the glass and take it back in and hopefully it fixes my issue.
T
Tbruz
Windham NH
To be clearer, its the rubber seal that breaks not the glass itself. Unfortunately you cannot get the seal separately from the glass. Check into your insurance coverage as well as I was able to get them to pick up all but $100 of the replacement costs.
Tbruz
beto7679
Tbruz
How did you get insurance to cover part of it, what coverage do you have?
csan2879
