Show off your 2015-2020 lowered tahoes and yukons
tglad
I thought for weeks about how much to lower my 'hoe. I live in Minnesota where winters bring lots of snow. Also with trips to the cabin and the occasional treks down forest roads there, I wanted to lower but lot lose the functionality of this kind of truck, I mean the front air dam is low enough at stock height. My desire would have been a 2/4 drop using drop spindles up front and coils in the rear. The beauty of this truck is that it doesn't have air-assist shocks, so the lower process was super simple. I decided to just drop the rear to level it out. I bought 2" springs from Crown Suspension and had them in within an hour. The running boards are now parallel with the street and realized the roof line almost seems it's designed to be parallel at stock height. Now with things leveled, there is almost a slight downward slope to the roof line that I really like. I'm really happy with only dropping the rear for now. Some day maybe I'll do more but this keeps me very happy for now!
View attachment 252384 View attachment 252385 View attachment 252386
This is exactly how out white 2015 sits. And I like the slight slope of the roof as well.
scr2500hdtx
Front is universal air strut bags over Bilstein 5100s. Rear is TBSS bags with 1/4 quick connect fitting tapped. Air management is Airlift 3H with dual 444C compressors and dual Seamless tanks 6x28. Wheels are 24x9.5 Status Juggernaut custom powder coated gloss black. 305/35 Yokohama
Do you have links to the bags used on the front. I’ve been looking into bagging the front.
Bigkevschopshop
Northside H-Town
This is my 2016 Yukon Denali with Tony’s 4/6 set at 3/6 with spohn uppers, lowers, and panhard bar. Has 24” Infamous wheels on 275/30 & 295/30.
The middle pics look like Heatwaves Spring Break Jam..... Haven't been down there since 2009 if I am right...
Ohannon7
Central Fl
2019 Yukon XL
Belltech coilovers
Belltech rear springs (with 1” spacer in)
Belltech street suspension shocks
FTM
We have a large family so it’s not as low as I’d prefer.
Ohannon7
Central Fl
2WD.
I think it rides nice, we have the dampening and rebound in the middle settings.
At first I just installed the rear springs to see how OEM struts would do. They didn’t last long and we would bottom out going fast on interstate overpasses. I installed the street struts in rear and did the FTM and it’s a lot nicer.
The front has been solid, no issues.
Wife wanted stock tire size but next time I will get a little fatter tire. We love the Yukon, bought it new and plan to keep it forever and put lots of miles, we are at 60,000 already.
I wanna install the drop spindles in front so the coil overs aren’t maxed out as well.
Happy to be here, have learned a lot!
Thanks all.
70cutlass
Slight drop on mine, but came out exactly the way I wanted. I didn't wanna replace spindles and also didn't want 2" drop.
Rear - Belltech 34324 no spacer, Arnott shocks.
Front - Arnott Struts, I replaced the springs with Maxtrac 1" drop springs 251510-8.
Rides smoother then when it was new.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Dang nice! You should call her Darth Vader.
justinakay79
