2005 Yukon 5.3 / stock- that crazy air box??
mountie
mountie
I believe it's the only tube like that, and probably why they can charge $150 for it. I haven't seen any in a long time, but used MITs seemed to pop up for sale once or twice a year in the classifieds from people returning their trucks to stock. They usually went for around $100.
You could get a $50 "cold air intake kit" off ebay and trash the filter and "heat shield". You might have to trim a couple inches off the tube's length since you'd be fitting it to the stock air box. Spray painting a satin black wrinkle finish would blend it in decently well with the rest of the stock equipment.
Something like this: https://www.ebay.com/itm/114741507699?fits=Year:2005|Model:Tahoe&hash=item1ab7207673:g:OjAAAOSwuFhgcAGx
If you wanna be extra fancy, use some T-bolt clamps. Here's some black ones: https://www.racepartsolutions.com/item/1903364-black-t-bolt-clamp-for-300-hose
Another option to keep it cheap and looking original is to cut the resonator chambers off the stock duct and epoxy them closed, maybe using pieces of the cut-off chambers. A little sanding and paint would make it like they never existed. A member here did this a couple years ago and, IIRC, measured the differences in air flow according to the MAF sensor readings.
There's the PVC or ABS plumbing pipe method, but I doubt you're looking to get that involved.
Well, that answers my question ( thanks all)..... I am just buying the MIT and drop it in.
Easy peasy.... I prefer..... I'll forget the 150 bucks spent next month......
mountie
mountie
Looks like you got everything cleaned up nice.
Looks good!:happy107:
Thanks..... I was inspired to clean as much as 'reasonable', ...removed / sanitized filter housing & new filter..... Cleaned rubber hoses & rubber weather shields @ radiator..... soft wire brush on the aluminum brackets / waterpump etc...... Next will use my new little powerwasher to de grease suspension areas....... Clean that stuff up !!! ( It actually is not that bad)
Man-o-man..... I wish I had a lift.......
Don't think the clean grooves in that wire loom didn't go unnoticed. :thumbsup:
Done..... The throttle noise is just a bit more / nice.
Looks great! Glad you're satisfied with the sound. Them mufflers were put on the factory tube to appease the nutless majority that are offended by the sound of Bald Eagles.
rick9667
