- Joined
- May 9, 2018
- Posts
- 7,225
- Reaction score
- 14,058
Where did you stop when you took the picture?
I had my camera ready to take the picture because I knew it was coming. It worked out with me stopping at a red light.Where did you stop when you took the picture?![]()
Ah, yes.... Those cop cars have red lights.....I had my camera ready to take the picture because I knew it was coming. It worked out with me stopping at a red light.
HahahAh, yes.... Those cop cars have red lights.....![]()
Unfortunately that fuse is good. I'm wondering if a wire melted or came unplugged. I used that rear pwr port for my air pump, which got hot a few times.AUX PWR 2, location: Fuse Block - Left I/P
I feel that my Yukon drives fine..... smooth...... But, I wonder if getting a fresh set of plugs ( even coils?)... Might make it better? I have no idea how old my stuff is....Checked out the Tahoe today--finally. Pulled the plugs. Cylinder 2 was discolored(black)and ever so slightly wet--not much. All other plugs were great. There's probably 500 miles on them since they were changed.
Cylinders 2,4,6 and 8.
View attachment 361288View attachment 361289
Cylinders 1,3,5 and 7.View attachment 361290
Looked great, as they should.
I tightened 3 loose exhaust manifold bolts on the driver's side. That's where I was having an issue with stf/ltf, bank 1. I guess that was the issue. Runs 100 times better, but I still heard a little popping from the exhaust. Nothing loud or anything, but I heard it.
I saw some antifreeze drip out of the right side heater core line. I guess I leaned on it when I was trying to pull that last plug. I pushed it in and gently wiggled it, and it seemed fine. I let it run for awhile, then took it for a ride. System didn't pressurize, so idk what to think about that. Needle didn't move a lot past 160 degrees. Heat worked. Guess I'll keep an eye on it. No more leaks tho.
Plugs can't hurt. How's your wires?I feel that my Yukon drives fine..... smooth...... But, I wonder if getting a fresh set of plugs ( even coils?)... Might make it better? I have no idea how old my stuff is....
I can relate..... Hard to keep track of all this fun 'chit'.F_Uck I posted in the wrong thread again.
Were you getting low oil pressure ?knocked out the oil pump pickup tube o-ring and oil pan gasket
Thanks for the coaching...... What were those REALLY nice wires? ( round coils)..The stock plugs and wires of an LS are generally "good" for 100-150K. But, it depends on the condition of the engine and its operating environment, which, as you know, inspecting the plugs can specify. With an LS, I'd definitely inspect the plugs if I had never done so. Not so much to replace, but to compare the cylinders due to the PCV system. Coils tend to either work or not. If you were so inclined, you could spark test every cylinder to look for a variance to identify a weaker coil. Otherwise, it's just the plugs and wires that are the wear items.
....and I suppose to replace plugs with OEM? ( plug numbers?)
I guess I'm a bit lazy to search the recent posts. My bad....
Cool LEDS. You finally gave those useless slots a purpose.Looks great ! ( But no lit upper 3rd light ? )
They actually do have a purpose. They’re there to let the pressurized cabin air out so that when you slam a door it doesn’t pop your ear drums. There’s rubber flaps behind them on the body that act as a one-way valve. Air can come out but not in.Cool LEDS. You finally gave those useless slots a purpose.
