HELP!!!
N
NBSTAHOE
That dog is having a grand ole time!
Anyways, if it's not a major hassle to do so have you tried reinstalling the original air box and tube? I didn't pay attention in your original post to see that you have a CAI. Not that it's going to be your issue but I have read about the CAIs causing a lot of random issues with these engines when they are installed. Granted, they are usually from the MAF being installed backwards (doesn't appear to be in your case) or oil from the filter fouling the MAF ... but it would be super easy to confirm / rule out.
Yeah she a good ole girl lol, but the original box has been sold unfortunately…I had this CAI on with the original intake and the noise wasn’t present. Upgraded to this one and it’s been this way since.
nick0789
Was the intake purchased new or used? I'd imagine new since it didn't look dirty. If none of the vacuum lines are compromised, I'd be interested to see if the intake has any hairline cracks in it (if it were my vehicle). I know it's not the most fun thing to pull back off especially since it's been done 3 times now but I'd imagine a crack somewhere in one of the runners, where the throttle body meets, or somewhere else in the intake is a possibility at this point.
I'm not the most well-versed in intakes though, so take it with a grain of salt.
N
NBSTAHOE
Hey thanks for the quick responses, this was a used intake. That’s what I was thinking worse case scenario, is there anyway I can pressure test the intake itself? Like will the smoke prove if there was a crack in that location?
nick0789
The smoke test could tell you if there was an obvious leak; plastic won't expand or contract as readily as metal will, otherwise you'd be able to test it warm and [possibly] get better results. I'm not sure if you'll get enough smoke to find a leak source from a hairline crack but it wouldn't hurt to invest the $2 for a cheap gas station cigar and fill the intake up with smoke.
If the smoke test is inconclusive, it may be in your best interest / sanity to pull the intake again and inspect it thoroughly.
N
NBSTAHOE
I’ll give that a try tomorrow and post results.
Mudsport96
40.923,-89.488. Illinois
N
NBSTAHOE
Noises are a real pain to diag over the internet. Is it possible that the noise is actually the aftermarket throttle body whistling? And you are probably going to have performance and mileage issues until you get the truck tuned for the new intake.
This guy had a whistle with the tbss and 4 inch intake tube.
https://www.performancetrucks.net/f...mance-21/whistling-throttle-body-help-534510/
Yeah I’ve read where people have drilled holes in the TB. I’ve also read that for this particular mod that a tune is not required but wouldn’t hurt. I tried everything this guy tried, and some people get a whistle, and some don’t. I’ve replaced IAC and TPS. Acdelco and Delphi parts. Still whistles. Felpro gasket. Adjusting the TB screw will get it to idle fine, give it gas and the sound comes back. It’s raining today, but I’m really thinking bout pulling off the intake and starting all over. :(
MSI_Mark
I don't believe that drilling the TB will do anything for this issue other than increase your idle speed. In the shop we would use a smoke machine to diagnose the leak, if any. Here is a simple smoke machine DIY build. If you are getting a 440 trouble code, Diagnostic trouble code (DTC) P0440 stands for “Evaporative Emission Control System Malfunction – Large Leak.” You may have pulled a line loose during installation or something is cracked. I don't think that you are looking for a hairline crack, I'm guessing that it is something BIG
I’m betting there’s a vacuum line disconnected somewhere.
N
NBSTAHOE
I’ve decided to pull the intake again and see if it’s something I missed, it’s just been raining 3 in a row. :(
N
NBSTAHOE
Ok.
I used a cigar on the brake booster hose to see if I could spot any leaks. There where none. All hoses are practically new and in Good shape. The sound is coming from TB. It’s a Holley Sniper EFI #860008-1. The noise is coming directly from that. But there aren’t any leaks anywhere. I’m confused. :(
RET423
Your evap code is for "large leak" which means the evap system is seeing no vacuum at all, your leak is definitely related to the evap system which connects after the throttle body; so you may be hearing it from the throttle body but I doubt that is the source.
Remove the evap plunger and start the engine, then plug the hole in the intake with your thumb and see if the leak goes away; if it does you will know that the plunger or the plastic line is damaged.
N
NBSTAHOE
I’ve removed every single hardline and rubber hose checked for leaks. Didn’t spot any leaks. The sound only appears on first startup for a few seconds and then disappears after idle regulates. The sound is present when I give it gas, and when I’m downshifting coming to a complete stop. Sometimes at the stop it’ll surge up then back down. The idle is too high, and the noise is associated with the idle. Smoke didn’t detect a leak, and I visually didn’t detect any. New FelPro gaskets, IAC, TPS and again the TB Is a Holley Sniper EFI 860008-1. I’ve adjusted the TB screw to an ideal throttle and the noise will go away, it’s only present on start up, And acceleration. More notable with a cold start. The sound comes from the CAI. When you remove the CAI it comes from TB itself. Disconnect any sensor while the truck is running and it stalls. I’m lost.
N
NBSTAHOE
this is where I’m at. With IAC unplugged, no noise. When you plug the port, or connect IAC it makes THIS noise.
Mudsport96
That is air being drawn around the blade. Is there a minimum closed angle you need to set?
I only know what that is from my ford site. The older fords had a set screw to adjust the blades from closing too far and causing that. It was also used to some degree to set minimum TPS angle to achieve the correct voltage signal at idle or you get a poor idle quality. Read direction to see it there is anything you need to adjust.
Just for grins disconnect the tps and ever so slightly crack the throttle and see if it goes away.
Also is the tps adjustable on that unit?
Mudsport96
Never mind i googled it, there os an adjustable throttle stop. Slowly turn it until the noise goes away. May have to play with the tune to get a good idle after that. The blade is too far shut and it's forcing air around it to stay running.
N
NBSTAHOE
I did call Holley. No help. When I adjust the idle screw the noise will go away, during idle, if I crack the throttle it returns. Crack the throttle with the IAC unplugged the noise goes away completely. So do I reset IAC somehow? Measure voltage of TPS, then adjust the throttle blade?
johnsonwillie199
