Black Betty 2018 Z71 Silverado....build
Planning on getting stuck? ;)
no, but IF I do it's likely to be where no tow truck is going to go and the grip boards can be deployed quickly, the tow hitch shackle or bumper mounted shackles or similar are required for club runs "no tow balls"
Have you considered those ****** ropes, they've got a lot of give like the manila lines we used to tie ships to the pier with, only better.
Now that's funny, B-U-B-B-A is outlawed???
I saw those but the straps are more compact and are "tree savers". straps around a tree will do less damage than a rope or cable and there not allowed on a club run
I was watching some video's of some of the runs and in one place in particular they drilled a shackle into a large boulder because people were damaging the surrounding tree's
these clubs work with BLM and forest management to keep the off-road trails open for public use and not destroy everything, certain clubs will adopt a trail and maintain it so it can remain open.
Those hook up vehicle to vehicle, no trees and they don't snap like the ones we normally use.
I have this for when we play in the woods:
ordered more stuff a s-n-a-t-c-h block (doubles the winch capacity) and a air hose kit since I have a built in air compressor I can just connect to the outlet by the license plate and air up anywhere
I’ve had my eye on these. Look forward to seeing them installed and your thoughts on them.
ya I was just sitting here thinking today "I wonder if anyone makes a d-ring adapter" and walla they came right up on a simple search RC seems to be the only one that makes them I didn't see anything else out there, read some reviews and didn't see anything negative so i figured why not.
I have been looking around at other hardware for mounting the hi-lift jack and maybe a shovel or ax and the best deal seem to be the builtright industries bedside rack, looks easy enough to just throw on when I need it and take it off when I don't it just mounts to the factory tie down locations if I get the full kit it's the best deal I only need one side for now just to keep stuff from flopping around in the bed I tend to have a heavy foot I don't need a 25lb piece of metal slamming around the bed
I have a onboard air compressor (wireless one standard) for the airlift helper bags and it has a schrader valve port on the rear license plate, I figured I could make a air hose to air back up after a off road run and not have to carry a air compressor around, well it works sort of I tried it on a couple of the kids bike tires just as a test and the end result was the air compressor overheated on me and it has to sit for 25 minutes before it will operate again so.... either I can carry a compressor with me or upgrade the onboard pump there not cheap apparently i will have to call them and see if they sell just the heavy duty pump
Don't be a punk: https://www.completeairride.com/pro...8-5-3-6-0-6-2-ls-engine-driven-compressor-kit
Yeah, it's for a Gen3 and 4. I posted it for the idea. I'm sure someone makes a kit for a Gen 5.
that's a lot more than what I need, I am thinking more along the lines of a small compressor I can just mount in the spare battery compartment area, I was looking at the ARB today not sure how it will handle underhood temperatures is all, it would only see use to air up tires. Apparently the airlift pump is just for the helper bags and using it to air up tires will just burn it up duty cycle is pretty low. The ARB is like 21 minutes on 35 minutes off, info says it takes like 2 minutes to air up a 33" tire so that would work fine
Yeah, duty cycle is everything.
Speaking of, and I'm not suggesting it, but have you seen those inflators hoses that screw into a spark plug hole and clip on the tire's valve? You crank the engine to fill the tire. I think its more for a motorcycle cuz you'd probably kill the battery or burn up a starter long before you aired up a truck tire. It'd be a total PITA, but imagine eight of 'em linked together (with check valves) to use all of your cylinders. lol
nooo.. lol I will probably just go with the ARB
Set up an auto draft to another account. Make it $1500 though. You won't even notice
i thought about that but...oh I would notice, I play with my money too much I am always shuffling money around so I do not pay any interest, the only thing I have paid interest on was this truck and that was around 4% of which I cut the loan time in half. my income is very complex it's been stagnant for several months, spending plus income = 0 which is fine since I keep a balance it's the surprise income that bumps the balance up from time to time, with my ebay business I get paid daily not by the hour or salary, what might work is taking a smaller amount out weekly and hiding it somehow otherwise it will be poking me in the eye and become another source of money to play with lol.
pwtr02ss
Tennessee
I'm the same way with interest. Hate throwing money away. Good job on knocking out the truck. Financial discipline is hard
JasonW4141
