And if you have the tool, (Lisle makes a small cheap one) it's almost as easy to remove. Just an 1/8th turn of the tool and pull the tube out. No having to remove the spring clip with a pick and hoping it doesn't go flying somewhere never to be found!
This fitting type is called a Jiffy-tite fitting and is used on just about all makes/models of automobiles.
Lisle 22990 Jiffy-Tite 4-Piece Low Profile Disconnect Set https://www.amazon.com/dp/B00HDFDIAO/ref=cm_sw_r_cp_apan_glt_fabc_Z3P3QQM03AM30CJWRV8R?psc=1
Sparksalot
Bastrop County, Texas
I'm a lttle miffed about tire balancing. After THREE tries, it's pretty close, but not totally vibration free at 80. Wilst crawlingb through th desert, i had the windows down because of nice temps. What do i hear, clank clank clank, as the center caps rattle. I ended up pulling them off. I found what i feared, 11 of 12 of the spacers were missing. Now I have to make some. or stack some washers.
St. Louis
Spacers for the center caps?
Sparksalot
Funny story coming home from Big Bend. I passed a State Trooper going the opposite direction. about 5 minutes later, i see him coming up behind me. He follows me a few miles then lights up. Hmmm.
The entir car opens up and a bunch of guys jumped out. WTH, they're usually solo. I ended up talking with just one, but the others are looking all over and pointing at my obvious off road an overlanding adds. He was very young, so I'm guessing it was a training cruse for the lot. I forgot to ask.
The gent I'm talking with is convinced I'm with an agency. He spent five minutes trying to determine which one. He finally asks if I got thecopcar at an auction or something. I told him I had bought it from you guys.
At the end he did finally mention I was going over the limit just a bit.
ASG-MikeS
