Does anyone have a pic of a 21’ Z71 with a 22” inch rim and a 285/50/20 setup?
DWSmoot
Charleston, SC
Those wheels and tires look amazing. Would you be able to point me to where I can buy both? Also, would my 21 Z71 need to be lifted or can those just go straight on. Thank you!
Got the wheels on ebay but I would try OE Wheels LLC first. They wee on backorder when I was looking. When I ran the 285/50 r22s I had a 1: level up front and there was a slight rub at full turn but no big deal.
Currently have 285/55r 22 and have a 2" level all around.
Farmer10
Which wheels do you have?
DWSmoot
Charleston, SC
Don’t recall model but they are replicas of the Chevy factory wheel option. Went back and looked at the eBay purchase but not pulling up, no longer available.
Farmer10
I assume you have the smooth ride and not the air suspension correct? I’m looking at the 285/50/22 but don’t want rubbing with the air ride
Farmer10
Also I’d like to keep a p tire if possible. How does the e load ride compared to the oem?
Farmer10
It’s a more aggressive tire so yes it is a bit rougher ride.
How do you compare it to factory? I have e loads on my gx460 and they’re stiff. This Tahoe is my wife’s and she likes the factory ride. I could run the 285/45/22 to get the p rated tire but that’s a 32”. Not much sidewall left and I don’t know how it’ll look these big fender wells
DWSmoot
Charleston, SC
Rougher than factory. But I’m use to it as have had many trucks with larger more aggressive tires. IMO those tires will look to small.
Pepper1700
