That's what I'm afraid of lol. I did put a new battery in the truck after the swap... I'll just drive it around a bit and go from there. Wife scared to drive it cause the light is onAlso, you could have wired stuff wrong when you put it back together, damaged wiring in the swap out, or a bad wire finally just went when it was jiggled during the swap out. You might also want to check all your grounds, just as a matter of course. Good luck -- electrical demons suck.
Unfortunately it doesn't...Possibly a damaged front impact sensor or wiring harness. Does your scanner show any of the code suffixes that would tell you which one? (see the video for the suffixes)
Looks like I'll try looking for wires first... And then the front sensor's...Since it's a circuit code you may find a loose wire or bad connector. Worth a try to follow the wires back from the sensors to see if you can find an issue.
Anyone have one or where to find one availablemy guess is it's a pinched wire somewhere, probably need to find a diagram of the airbag impact sensor wiring harness and check the harness leading up to the 2 front impact sensors
@swathdiver might have itAnyone have one or where to find one available
Swap 2 new sensors and still getting this codeView attachment 357140
ya right side, you may want to put a meter on the harness and see what it reads, this video "may" be helpfulOem gm ones....
I check the wiring it all looks fine but I might need to pull it all out.
Or just get a better scanner to pin point the issues.
The code is most likely pin point to the passenger front side correct? Not driver side
