Engine swap air bag light now
Tmoney10
Socal
Anyone know how to get this fixed? Swapped in my rebuilt motor and got all these codes I deleted them with he scanner but pops back on right away
S33k3r
Dallas, Texas
You might want to let it sit for a bit, and then recheck. We had a similar issue when we replaced the battery on my daughter's Sierra. The airbag code cleared in about a day. This is a known issue, per other groups of which I am a member, but no one could tell me why it worked.
S33k3r
Dallas, Texas
Also, you could have wired stuff wrong when you put it back together, damaged wiring in the swap out, or a bad wire finally just went when it was jiggled during the swap out. You might also want to check all your grounds, just as a matter of course. Good luck -- electrical demons suck.
Tmoney10
Tmoney10
Socal
That's what I'm afraid of lol. I did put a new battery in the truck after the swap... I'll just drive it around a bit and go from there. Wife scared to drive it cause the light is on
Possibly a damaged front impact sensor or wiring harness. Does your scanner show any of the code suffixes that would tell you which one? (see the video for the suffixes)
Tmoney10
Tmoney10
Socal
Unfortunately it doesn't...
Since it's a circuit code you may find a loose wire or bad connector. Worth a try to follow the wires back from the sensors to see if you can find an issue.
Tmoney10
Tmoney10
Socal
Looks like I'll try looking for wires first... And then the front sensor's...
my guess is it's a pinched wire somewhere, probably need to find a diagram of the airbag impact sensor wiring harness and check the harness leading up to the 2 front impact sensors
Tmoney10
Tmoney10
Socal
Anyone have one or where to find one available
Tmoney10
Tmoney10
Socal
Okay so I took off both sensors, pulled the srs fuse.. cleaned both sensor they both look fine. And still getting this cide
New sensors, did I read that right? What brand?
Need a less generic scanner on it, like a Tech 2, which will better indicated the nature of the fault. Could be a wiring issue, bad or incompatible sensor, etc.
Be sure to save your old sensors; you'll want to match the part number for new sensors. Best to use OE for these replacements.
Swap 2 new sensors and still getting this codeView attachment 357140
it's probably a short as I explained previously
B0084 code possible causes​
  • Faulty Front End Sensor 2
  • Front End Sensor 2 harness is open or shorted
  • Front End Sensor 2 circuit poor electrical connection
  • Faulty Inflatable Restraint Sensing and Diagnostic Module (SDM)
Tmoney10
Tmoney10
Socal
Oem gm ones....
I check the wiring it all looks fine but I might need to pull it all out.
Or just get a better scanner to pin point the issues.
The code is most likely pin point to the passenger front side correct? Not driver side
Oem gm ones....
ya right side, you may want to put a meter on the harness and see what it reads, this video "may" be helpful
KEEP IN MIND YOUR MESSING WITH THE AIRBAG SYSTEM, A MISTAKE CAN BE EXPENSIVE
CKendrick
