Bose from the factory but….
Ghost10
If I switch the audio to the rear speakers there is zero bass
Sup with that ? Seems like all the bass comes from the driver and passenger door speakers. Is this normal ?
if you do not have a center console subwoofer then yes, without the subwoofer gm made the front door speakers the bass source
Ghost10
Ghost10
I see that you can buy center consul subwoofers does that go underneath the center consul and is it plug and play ?
if I can get another Sub in here that would be great
if you have a center console subwoofer maybe it turns off if the audio is switched to the rear?, my silverado does not have the center console so they made the door speakers the subs, check your rpo code to see which system you have
Ghost10
Ghost10
Where can I find the rpo
Nothing in glovebox
Ghost10
Ghost10
There are some cool subs that are designed & will fit under the seat
I’d like to keep it plug and play if possible as in I don’t want to be changing nothing
Nothing in glovebox
I forgot they started making them qr codes around 2015, you would have to scan the qr code in the drivers door jamb to get the rpo list, if you have a newer smart phone you can just use the camera to scan it
RBinMcD
I missed which yr yours is. My 2011 had the Bose (non-Nav) system. The sub under the console is very small, maybe 6".
4years ago I replaced the all door speakers including the tweeder in the A-pillars. With same sized Infiniti branded speakers from Crutchfield for less than $400. Huge improvement including plenty of base aside from the anemic factory sub. Note that the factory Bose a 2 ohm which is more efficient needing less watts. I like high quality but not blasting sound. This was perfect.
Later I replaced the head unit so I'd have Apple car play. The speakers were the main improvement.
I just bought a '15 Yukon Denali with the Bose system. I'll do the same with the speakers. Sorry for the long post but this worked pretty good for not much money. Good luck!
NardDog
Bose systems moved the rear subwoofer to the center console, standard systems dont. I recently added a rockford fosgate powered sub and I really like the new bass im getting
Sparksalot
Bastrop County, Texas
I’m curious if all Bose systems have a subwoofer? I have a Bose system in thethirdtwin, but have seen no evidence of a sub in the console.
I would speculate in a ppv maybe not or it was removed for other equipment, if it had no sub then the front door speakers will be 6X9 and will provide the bass sound
Hodmjstone
