08z71bgm
These are what my pads look like. The other ones don’t fit my caliper brackets.
ChesterfieldIt's a davenport not a couch!
hmm, ok after a little digging around it looks like there was some weird stuff going on design wise from 05-08, those castings look smaller, it looks like you could likely easily upgrade to later model calipers if they started leaking or something later on down the roadView attachment 355570
the castings they fit look smaller, from 05-08 there were some mixed castings numbers 2xx-2xx & 3xx-3xx, and then regular castings all in the same time periodThe ones with the holes- possibly for the drag reduction clips ("spreader springs")?
it appears the knuckle is the same on all the 07-14 suv's so you would be able to change the calipers to a later model
also appears the 07 pickups used the same knuckle but it changed in 08
ya I am glad I went with my 12 I did a bit of researching parts compatibility before I decided which would have the most parts available later on down the road I tend to keep vehicles for a long time, just seemed like 10 & later had more compatible partsSpeaking of differences, I have one of @kbuskill's old hubs. I couldn't fit any of the OEM wheels I tried onto it, but they fit perfectly on my Hoe. I had to grind down the part that slips through the hub bore on the wheel.
Yeah, GM does that stuff a lot, but apparently there is a difference between Arctic and Summit/Olympic. Might not notice unless you see them side by side. Here’s a pic I found. The Camaro closer to the camera is summit apparently. But I swear mine looks more like the vette here. Oh well I give upBut is there really any difference? The exact same color will have different names between being on a Chevrolet or on a GMC or Cadillac, Buick, SAAB, etc. I wanna say they even change the name between year models of the same brand.
I do see calipers in my future. So what would be needed to update to the larger pads?hmm, ok after a little digging around it looks like there was some weird stuff going on design wise from 05-08, those castings look smaller, it looks like you could likely easily upgrade to later model calipers if they started leaking or something later on down the road
Just order calipers that are not noted as "cast#" or order them for a 2009 or later I didn't notice any having a "casting" notation after 2008 but some still looked like they had a casting numberI do see calipers in my future. So what would be needed to update to the larger pads?
But the pads meant for the larger calipers don’t fit the bracketsJust order calipers that are not noted as "cast#" or order them for a 2009 or later I didn't notice any having a "casting" notation after 2008 but some still looked like they had a casting number
I replaced mine with these ac delco heavy duty "coated" ones, they appear to be out of stock at the moment
I am pretty sure the only difference you are seeing with your current calipers/pads is the mounting tabs are different size if you go with a later model you won't have that issue just order pads for a 2009 or laterBut the pads meant for the larger calipers don’t fit the brackets
it's some music that was streaming from a online station I listen to from AustriaIs that the music that's actually playing while driving or was it added to the video afterwards?
Nice dubstep background music. It’s party timeI wonder if the dodge boys are ever surprised I keep up, typical morning commute
The driver is a stupid idiot, hauling ass in traffic..... If a driver, ahead, decides to lane change, ..they are not looking 300 yards behind for a 100 mph vehicle.Nice dubstep background music. It’s party time
very true, don't do it.....and always check your mirrors before changing lanesThe driver is a stupid idiot, hauling ass in traffic..... If a driver, ahead, decides to lane change, ..they are not looking 300 yards behind for a 100 mph vehicle.
