Migration from ACDelco TDS to GM Techline Connect for Tech 2 Users
Hi Folks,
As you probably know, ACDelco TDS (TIS2Win) site for Service Programming Software (SPS) has been retired, effective September, and current subscription holders need to migrate to its replacement GM Techline Connect. Below, I offer you the process that I used to perform this migration. Any other folks out there who have already gone through this migration process, please chime in with your thoughts and perspectives.
Converting from ACDelco TIS Web to GM Techline Connect
Log into ACDelco TIS Web (https://www.acdelcotds.com/subscriptions#), as you would normally do. Upon trying to log in, you may be required to enter a code generated by TIS Web and emailed to you, as an additional level of security. Once logged in, you will see a message that TIS Web has been retired, and you will be given the opportunity to download and install GM Techline Connect, its replacement. If you don't see a migration message, find your active Service Programming System subscription, and click on View. Then in the view, click on your truck’s displayed VIN, and you should see a button for 'Download Techline Connect'.
Download and install GM Techline Connect. Follow the directions on your screen, and this may take a while. Once complete, close all applications and re-boot your computer. Any new shortcuts created on your computer’s Desktop for GM Techline Connect will not work correctly for access to GM Techline Connect, so delete them.
Note: To successfully connect to GM Techline Connect, I need to temporarily disable my MalwareBytes Exploit Protection service first, each time.
To access GM Techline Connect, go to your original ACDelco TIS Web site and log in. Once logged, find your active Service Programming System subscription, and click on View. Then in the view, click on your truck’s displayed VIN, and you will automatically be connected to GM Techline Connect. The connection process takes a while, and there is a medium sized pop-up GUI that displays the progress status in connecting to GM Techline Connect. Sometimes this GUI gets buried under other open windows, so you may want to minimalize any open windows, during the connection process.
Once connected to GM Techline Connect, you may see a message that you do not have certain permissions, and just ignore this message, as it pertains to other subscriptions that you have not purchased.
That was the good news. Now for the not-so-good news.
The not-so-good news is that GM Techline Connect is not Tech 2 user friendly, and you have to search around for the Tech 2 tool info (the site automatically defaults to MDI 1 and MDI 2 tools). Also, my experience so far is that you cannot re-program existing modules or program new modules in your truck with a Tech 2 through GM Techline Connect at this point in time. The connection simply does not work, either for tech 2 remote programming or for tech 2 in-line pass-thru programming.
I have had 2 lengthy calls, so far, with GM Techline Connect Support, and so far, they have not been able to come up with a resolution through GM Techline Connect for programming with a Tech 2. I needed to re-program my Electronic Suspension Control Module, and in order to do this, my GM Techline Connect Support Engineer had to obtain a 1 day subscription license from senior Support management for me to use the retired ACDelco TIS Web to complete this re-programming process.
This workaround comes with a restriction in that programming with the Tech 2 can only be performed in the Tech 2 in-line pass-thru mode. For some folks, this may not be an issue, but for me, my computer is not movable, and my truck is parked at least 75 feet from my computer. Fortunately, I was able to dig up a 100 foot data cable to accomplish this programming process.
Further, the GM Techline Connect Support Engineer escalated my issue to senior Support management, but he is not confident that they will make a permanent update to the GM Techline Connect site for Tech 2 users. Since, I have an existing subscription that states that Tech 2 tools are supported, they were obligated to get me that workaround using ACDelco TIS Web.
On a positive note, the GM Techline Connect Support Engineers are outstanding (having spent 20+ years in technical support at one point in my career, I feel that I am qualified to make this assessment). Each time, the GM Techline Connect Support Engineers spent over an hour with me, and they got me where I needed to go. If you need to contact GM Techline Connect Support, use the phone menu below to get to them. You can wait up to 20 minutes for an Engineer (well worth the wait), or you can also arrange for a callback from them. When talking to them, imply that 'you use your Tech 2 for your shop'.
Support Phone Line for GM Techline Connect
1-800-825-5886
Select 3
Select 2
Select 1
Select 2 (may have to listen a bit before being given the option to select 2)
I'll update this thread with additional experiences, as I progress through this new maze. Any comments from other folks are highly welcome.
Hi Folks,
1-800-825-5886
Select 3
Select 2
Select 1
Joe, somehow this awesome post slipped by me! Thanks for posting it. Now I want to program something! hahaha
Here is the sequence of steps that I used to get to the Tech 2 tool screens, when using GM Techline Connect:
After logging into Techline Connect, this is the first screen that I see.
I select my truck under the Recent Vehicles column, and then I see this screen, which shows me modern MDI-based tools, but not the Tech 2:
I click on Cancel, and I see this screen:
If clicking on Cancel does not produce this screen above, then click on the SPS2 tab at the upper left of the screen.
I click on Manually Select Tool, and I see this screen:
At this point, the Tech 2 needs to be connected to my computer (If I were doing an actual project, I would also have to connect the Tech 2 to the truck at this time). I connect my Tech 2 to my computer, select Tech 2 Legacy Pass-thru and and Reprogram (or Replace and Reprogram, depending on your situation). I click on Next, and I see this screen, where I can see the list of control modules:
At this point, the Tech 2 would need to be connected to the truck to proceed further, as Techline Connect would need to retrieve information from the truck regarding the installed modules and the current version of the software that is installed on each of these modules, so that can know what the current baseline is. Then, you could click on the appropriate control module, and it will list all of the software versions available, plus the version of the software that the current control module has installed.
Hopefully, this is helpful to folks exploring GM Techline connect.
pwtr02ss
Tennessee
Hi Folks,
1-800-825-5886
Select 3
Select 2
Select 1
Is the subscription required to use a tech 2? Cost? This info may been in your post, I started reading and realized I had no clue what I was reading lol
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
It’s not required to use it for troubleshooting and bidirectional operation. A subscription is only required if you need to program a module.
pwtr02ss
Tennessee
Thank you. I never visit this section. I scrolled down and found the master thread. I’m reading through that now
pwtr02ss
Tennessee
Don’t overthink it. Watch a couple videos on Youtube and then play around with it. Research what you need to if you need to.
I’m just recently learning of the abilities of these things. Also, how much stuff requires having one. Its overwhelming at first. I have hp tuners but the capabilities are no where near the tech 2. I need one
The Tech-2 will work for most of your fleet, not the '74 or the 2019. For the latter, you would need a laptop running the GDS2 software with the MDI2 interface or an aftermarket adapter like a VXDIAG NANO.
We need such a scan tool to properly diagnose things, everything from the engine, brakes, suspension, AC to interior switches and lighting.
pwtr02ss
Tennessee
It would work on some things for the '74. Its kinda nnbs ;)
Thanks for the info guys. China car website seems to be the best place, from what I can tell. I'm going to dig into this a little more and familiarize myself before ordered.
I want to make sure I'm smart enough to operate the thing!
Edit: will this stuff work on windows 10? I've seen confirmation in the other thread about windows 7, but I'm only a few pages deep. I only have one windows computer, the others are apple
George B
¯\_(ツ)_/¯
That depends on if you want to use the discs and tis2000 otherwise I believe you can use techline connect as passthrough. The only thing tis2000 gets you is the ability to read and manage captured and logged data. Also flashing calibrations into modules for the NBS and OBS stuff. You need techline for the NNBS anyway.
pwtr02ss
Tennessee
@Joseph Garcia is using Win10. (It's the TIS2000 software that should come with the Tech 2 that is finicky about the OS.) Using Techline Connect works on Win 10.
Awesome! I’m pretty computer illiterate, especially windows. I didn’t want to have to try to figure out a way to go back to an earlier version of windows. I only have that pc for hp tuners So good to know it’ll be able to perform double duty
sorry to clog the thread with questions that have probably been answered 100 times if I would just search. Thanks again guys
George B
¯\_(ツ)_/¯
sorry to clog the thread with questions that have probably been answered 100 times if Inwould just search. Thanks again guys
Im not super literate either. I found a super easy tutorial with likns to the downloads and added a virtual windows XP to a windows 10 PC. It was easy.
You do not need a computer to work with the Tech 2, for troubleshooting and systems monitoring, which covers 95+% of the use cases you will perform with the Tech 2. You do need access to a computer to program certain new control modules that you install to replace old worn out modules, but that is a relatively rare occurrence, for all of the times that you will use a Tech 2.
You can use a computer with a Tech 2 to see plots of various components of your truck's systems, which will show up on a larger screen than the small screen of the Tech 2, but I've never had any issues with viewing real time activity and plots of recorded activity on my Tech 2's screen. In these instances using the software supplied with the Tech 2, there will be limitations on which operating system you use, since the software was created before Windows 7 and Windows 10. Some folks have been able to use the software with these newer operating systems with various workarounds, but as I previously stated, in most cases, you do not need to use a computer with the Tech 2.
With the new GM Techline app, it is entirely wed-based (no thick client), so it does not matter what operating system you are running on your computer, nor does it matter which browser you use on your computer to access the Internet and GM Techline Connect.
Hey Joe, on one of the images you posted, it listed Remote Tech-2 programming. Can we still do that when able? Or do we have to use Pass-Thru from now on?
The GM Techline Connect Support Tech told me that Tech 2 Remote Programming does not currently work in the GM Techline Connect, and he doesn't think that the GM Techline Connect Admins are going to correct that issue. So, it is likely that only Pass-Thru Programming will be supported going forward for the Tech 2 in GM Techline Connect.
JamesinAbilene
