New member to forum -- searching for my 07-14 Tahoe/Yukon
Bill 1960
Testing the Limits
Okay -- tell me why I shouldn't buy this 2009 Escalade 6.2 . Cali car the entire life, 4 owners per the carfax (but the last owner was BMW of Valencia had it for a few months before sending it to auction...I wish my friend who had Manheim dealer access was still alive, Mark would have given me the auction price). Now it is at a small used car dealer in Long Beach who wants $17,995 for it. It is the only 6.2 Escalade around that meets my "color" (not black, not white) requirements. Hate to buy from a used car lot...but...maybe it needs a test drive.
It’s worth a look IMO. I’d be looking for repairs or repainted and all the usual indicators of crash damage or incipient mechanical failure.
There’s a question in my mind as to why it’s been unsold for so long.
Geotrash
Dave
Richmond, VA
I've had good luck buying from small used car lots like that. Knowing that it's a lifetime California car is huge. No AFM - another plus. Be prepared to deal with some deferred maintenance items (e.g. rear air shocks, compressor, motor mounts). Parts are inexpensive relative to other luxury brands, and they're easy to work on.
I bought my '07 from a lot like that in Colorado - unbeknownst to me about 2 weeks before they went out of business. It was an Arizona car all of its life, and was clearly garage-kept and meticulously maintained - probably by an elderly person. I know this because the GPS history was full of clinics in the Phoenix area for various aging-related needs. Anyway, it needed motor mounts and a few odds and ends like new struts for the liftgate but was otherwise tip top. Since then I've done a handful of things, but for a car with 220K on it, it's beautiful. My neighbor works for Carmax and comments all the time about how clean it is.
Go get it!
I was getting ichty to spend some money and was looking at this 2007 Yukon, but it has a bunch of owners and is from the era of the dreaded AFM. The seller is asking way above blue book, but in LA most of the cars are thrashed and being sold by sketchy dealers and kids who think they are dealers.
But some of the research I've been doing on the AFM issues and features makes me want to start seriously looking for the unicorn 09 Escalade or 09 Denali or 09 Tahoe with the 6.2 L9H. Somebody find me one of those on the West Coast. :) I promise that if I buy the car I will send you something cool in the mail.
Can someone tell me which digit in the Vin identify the 6.2 and the AWD? I can figure it out with a vin decoder (https://www.truecar.com/used-cars-for-sale/listing/1GYFK23249R260546/ THIS IS A 6.2 AWD -- but only because https://www.gmforum.com/vindecoder.php?vin=1GYFK23249R260546). But I can't find the digit by digit decoder.
You have to memorize the VIN sequences for each year or group of years as they changed during the production of the GMT900s. Eighth digit 2 is for the L9H motor.
The 5th digit tells you the drive type, C for RWD and K for AWD or 4WD from 2007-2010. After that it is 1 for RWD and 2 for 4WD and AWD.
If you care looking for the coveted 2009 6.2 Tahoe, the VIN sequence you scan for is 1GNFC332 or 1GNFK332 RWD and 4WD respectively.
There are 2008 6.2 Tahoes and all are RWD with the L92 engine, VIN 8.
GMC also had some Yukon XL SLTs with the L9H in 2010.
GM has VIN Cards for every year that you can study to memorize. This is how I find the oddities to share and buy, like our 6.2 NHT Sierra.
vinbart
vinbart
The saga continues. I took the 09 Escalade (link above) on a test drive. Coolant was clean. Oil was clean (although it seemed filled very high -- or the dipstick was covered in spray). The interior of the car is very nice (except a cracked dash) and some minor wear issues. Took it for a test drive -- it rides and drives nicely, accelerates appropriately fast, doesn't pull in either direction, stops quickly and straight (i've bought sold and driven many cars over the years, so I pretty good at assessing vehicle condition, but this is a new car to me). Everything seems to function inside the car - switches, gauges, lights, heater, parking sensors, AC, seat auto fall down thingy. No evidence of any body work on any of the panels, no overspray that I could detect by pulling back seal, but the front valence is showing some rock and curb rash. Bottom of the car shows some signs of leaking oil/ATF. The only thing that didn't work is the TPMS -- it showed -- psi on all four tires. Not sure what is going on there. Warmed up-- Oil shows 30psi at idle, 24psi against the torque convertor and it had a slight vibration from the steering wheel that I didn't like. The engine was also idling around 500rpm when in gear and at stop. MMmmm. Then I noticed a check-engine-light. The CEL amber light would stay lit up after your key-on and no start -- so the seller (a small used car dealer) pulled out his scan tool and scanned it as P0172 Fuel Trim Rich Bank 1 (I think there might have been a second code, but it was either another instance of P0172 on his scanner or P0173). We started and stopped the engine a number of times and eventually the code persisted as a solid-on CEL. The dealer is taking it to his mechanic who will diagnose the code and fix it. Few thoughts -- this is a California car that means it did not have a CEL and it cleared all 100% of its OBDII readiness checks to pass emissions 3 or 4 times this calendar year (according to the carfax) on 4/02/2021, 7/15/2021 (in Palmdale when it was offered for sale at a dealer in Valencia), and then on 9/27/2021 and 9/28/2021. I could easily believe that one of those smog checks were a "wink-wink-nudge-nudge" smog tech who could get a pass by using another car's OBDII port, but I can't believe that all of them were fake smogs.
Obviously, this fault code needs to be fixed and then it needs to run a full cycle of readiness before I will accept that it is good to go. But...what should I be looking at? I've got a handfull of pics I could share.
Pics follow:
GMT800 2005 Tahoe Z71
Navy Supporting Member
Sway bar frame bushings look to be splitting out. Vibration from steering wheel, when? Trace leaks still, of course.
Pics follow:
View attachment 354679View attachment 354680
View attachment 354681View attachment 354682
I see new sway bar end links and new Arnott struts in the front. Did you notice if the rear Auto Level Control aired up when you first started it? The suspension is kinda pricey, so if it's been repaired, that's something to consider.
I believe the CEL should be on with key on/engine off and goes off after startup if no DTCs are present. Chances are that the P0172 is a minor offense. If there aren't any other options that you feel better about and this one checks out otherwise, I wouldn't let that be a deal-breaker as long as it's priced accordingly. It could be a slightly sticky injector or O2 sensor that needs to have moisture burned off- problems that could've arisen from it sitting on the lot for a while that weren't there before. It could just be an old O2 sensor issue that, coincidentally, sprung up while in their possession. What you'd need to confirm is if the problem is actually repaired and they didn't just clear the code(s). Such a code would take a few drive cycles to resurface if the problem was still present. So, they could clear it before you get there and it might not come on until a few days after you buy it. A simple scan tool that shows status of readiness monitor would tell you if it has completed all drive cycles required to satisfy the readiness monitors.
vinbart
vinbart
Vibration when sitting at idle. Seems to be more NVH that I'd expect from a well running GM V8. Maybe it is related to the CEL. Or it could just be in need of new engine and trans mounts.
These LS engines are hit-and-miss (pun intended) with having a smooth idle or not. But, with it having that code, I'd have to consider that they may be related. It's a rich code, so, either an injector stuck open or a weak spark on Bank 1 (driver side).
As for the weak spark, maybe it has original spark plugs? Or, maybe they were recently replaced but with crappy plugs or even the crappy counterfeits of good OEM plugs. Taking it to the extreme: It could have the old style rocker cover, allowing it to get oil in the PCV system and, ultimately, the rearmost combustion chambers, carbonizing them and fouling the plugs. The plugs should be inspected and a compression test ran on the engine, if even just the rearmost cylinders. If compression is good, scope the cylinders for carbon. If carbon is present, perform the cleaning outlined in this TSB: https://static.nhtsa.gov/odi/tsbs/2014/SB-10065822-9133.pdf . Instead of GM's upper engine cleaner, I think member @donjetman used Motor Medic or some other much cheaper stuff with great results.
Of course, I don't see the car lot going anywhere nearly this far in diagnostics or repair.
vinbart
vinbart
Yeah, I'm thinking they just want to get rid of the car at this point. Which is fine by me -- I don't mind some elbow grease and a good time with sketchy cleaning solvents (24 Hrs of LeMons racers raise your hands!). The lot says they've got a mechanic who will diagnose and fix the CEL.
If you do decide to buy the rig, make sure you get a detailed report of the diagnostics, parts replaced and repair work for that fix and what warranty comes with it.
Geotrash
Dave
Richmond, VA
That fuel trim rich code can also be triggered by a failing fuel pressure regulator, which is in the tank. That's what turned out to be the root cause of the same code in my '07 last year. FWIW. If so, it will likely only appear intermittently, which could be why they were able to get it through the smog test. The code will clear itself if it hasn't detected the problem for a few cycles.
vinbart
vinbart
Oh yeah, FPR not working would indeed cause more fuel than expected, certainly in open loop mode, perhaps even in closed loop mode if the injectors can't meter out a small enough amount of fuel at some minimum pulse width.
Guys -- I just want to say, as a new member to this forum, you guys are super helpful and I appreciate all the suggestions and advice. Really good group of people here, I will become a regular once I've got this thing in my garage. Thanks again.
Could I bother you to share your method for searching by VIN? Any popular listing sites that search by VIN?
As far as I'm aware Chris, nobody allows a person to search by VIN or partial VIN. I've sent emails to all the popular places with no response.
When running a search, I'll often have to open up each ad to view the VIN. 64 GB of memory makes this easy but places like Auto Trader would kick me out after a while for a day or so.
So, when looking for 2009 6.2 Tahoes:
K332 for 2009 6.2 Tahoe LTZ 4WD
C332 for 2009 6.2 Tahoe LTZ RWD
When we were searching for 2009 XFE Tahoes and Yukons:
EC233 - 2009 XFE Tahoe LT with LC9 motor
EC333 - 2009 XFE Yukon SLT with LC9 motor
For the 2010 SLT XFE Yukons:
MCCE3
For the 2010 Yukon XL SLT with the 6.2 L9H:
KKE2
When we were looking for NHT Sierras we looked this way:
V2VE2 for 6.2 Sierra Extended Cab NHT SLE
V2WE2 for 6.2 Sierra Extended Cab NHT SLT
U2VE2 for 6.2 Sierra Crew Cab NHT SLE
U2WE2 for 6.2 Sierra Crew Cab NHT SLT
vinbart
vinbart
This thread is getting a big long/old -- I am going to start a new thread with this question:
Hey guys, I'm going to get another look and test drive of the 09 Escalade that I mentioned before (the tan one, they claim that the CEL was fixed, but I'm waiting for the paperwork from the mechanic).
What specific items should I be looking to make sure they work? I've got the "check the air suspension on key-on after sitting overnight, but what else (specific to a 2009 6.2 AWD Escalade that I might not be aware of) should I be looking for? Yes, the dash is cracked. :)
Thanks in advance!
MCCE3
KKE2
Ah. I thought I missed a special search feature on one of the sites. At least I wasn't working unnecessarily harder. Thanks for your insight and for the warning about Auto Trader.
Speaking of XFE, that's what my neighbor bought (an '09) after totaling his '07.
Those have always intrigued me, especially the 2010s. Always wondered if they got VVT for their LC9s as all the others, their mileage should be even better than a 2009s. They are lowered like the cop cars and have other weight/fuel saving features. We were going to get one but my wife wants more horsepower.
Aren't they only good for 1, maybe 2 extra MPG? I'll have to check his to see if it has VVT. All I've noticed on his is the unique spare wheel and I think his might have aluminum lower control arms. Oh, his was lower than mine when he lowered it with all the same components that mine has. His sits how I want mine to.
An '09 won't have VVT but a 2010 might. Yes, they were rated the same as the regular 2010-2014 models, 15 city and 21 highway. This was at the time when our older ones were rated 14-20 with the 5.3.
They had lower rear springs, aluminum lower control arms, the aluminum spare and other weight and gas saving features, can't remember them all at the moment but have written about them on here in detail before.
An old one of these would make a nice candidate for a 6.2 with a supercharger! They were lighter too with a GVWR of 7000 pounds.
ASG-MikeS
