Brake line diagram - SOLVED
S
shegarty
I think all of these are for the master to dist block. Here's the offe
Well, I hope @915_Tahoe chimes in then.
I found a replacement in a kit and got it installed. But now I think I need to find a shop to bleed the system for me.
S
shegarty
There is a list of members that have a tech 2. Maybe your new best friend lives nearby.
I'm going to try an old school vacuum bleed and if I get a decent amount of pedal feel back try activating the ABS pump a few times and then bleed again. Might have to do this cycle a few times based on what I've read so far but still preferable to a tow and paying someone else. I'll check out the list but I'm in Canada so I might not get lucky.
S
shegarty
I have a buddy that is in Canada that has a Tech2.. Where are you?
I'm in Ontario about an hour east of Toronto. But now I have a broken bleeder to deal with, ironically it was the newest of the four - go figure.
S
shegarty
Maybe this will help, if your still needing it. Let me know what othe info you need.
Thanks so much. It looks like it is part #24 connecting to part #3. Apparently the line is no longer available as an individual part but I was able to find it as part of a line kit. Just for future reference what exactly is part #3 called?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Brk Press Mod Vlv Frnt Pipe
(Length 565mm)
Gm#15166887
oh05ext
Ohio
I just did the brake lines on my 05 yukon denali this weekend. I bought a kit and did not need to change the lines from the master to the block. If I have the line you can have it if you cover shipping. ill pm you this afternoon shegarty
Ihaveatahoetoo
