Ss fuel line install
kennybhybrid
Hello all. I have a gas line leak on my 05 denali non flex and i decided to replace the lines with ss tubes stainless line kit. It comes with two lines, 1 for fuel vapor and the other for the main gas line. Does anyone have a diagram of the routing for the oem fuel lines, or have experience replacing the lines with stainless. Everything online shows the 00-03 never 04-06 yukon/tahoes. The lines are different. Thanks
B-train
No diagram here, but can you get underneath and take pics of the routing for reference and then install the new? I like those kits, pretty slick idea. You should have one larger in diameter. I'd look under the hood and measure the line that connects to the fuel rail and you'll have your answer. Dropping the tank will tell you the rest. Good luck, rust sucks
bsully456
