2012 Yukon XL Denali 6.2L Cam Swap Thread
Geotrash
Geotrash
Dave
Richmond, VA
Couldn't wait any longer - just had to get into it, so I pulled the passenger side valve cover and everything looks solid. A little end play in the BTR trunnions, but they were that way when I installed them, and everything else is snug. Next step tomorrow will be to pull the intake and valley pan to get a looksee at the cam and lifters.
wsteele
Did you start it up with the valve cover off? Maybe the sound will change enough to give you more of a clue.
To me, from the clip which is admittedly hard to tell anything with my game boy speakers, it didn't sound like lifter tick.
Also, have you checked some of the other obvious stuff like exhaust manifold bolts, etc?
Here's hoping it isn't major.
Geotrash
Geotrash
Dave
Richmond, VA
No, it's pretty hard to start it without the valve cover on. Sprays oil everywhere and gotta hook up the coil pack on that side, etc. It's not a typical lifter tick, but it's happening with every rotation of the camshaft. Sounds very similar to when I had that lifter dragging on the cam after the first cam swap. Exhaust manifold bolts are secure, spark plugs are tight. Thanks for your well-wishes! We will soon see :)
wsteele
I didn't get a great deal of oil sprayed around when I ran my with the cover off, although it was only idling. But no matter, may have not given any more to go on anyway. Sounds like you have a handle on what may be going on. Here's hoping for the best.
mattbta
Frisco, TX
Watching. I used the same lifters when replacing my Castech heads last summer. No cam and only a 5.3, so should be mild on the valvetrain.
Good luck, hate to see problems.
Geotrash
Geotrash
Dave
Richmond, VA
Sorry Geo… hope you get it sorted soon and at minimal expense!
Thanks for the support! Gonna set a stopwatch tomorrow with a goal to have the heads off and lifters on the bench in 2 hours or less. I’ll let y’all know how it goes.
This would mark 2 different lifter failures with 2 different brands of lifters on 2 different cams - this one with only .553” of lift. Both sets manufactured toward the end of 2020. Even GM is having failures on their lifters made during that period. Covid parts!
Geotrash
Geotrash
Dave
Richmond, VA
We have our smoking gun. This lifter is from the #2 cylinder and was starting to fail the exact same way that the Vinci lifter failed on the first cam swap. I believe what’s happening is I made the mistake of reusing the lifter trays from Vinci, and they do not hold the lifter well enough to keep it from rotating slightly as it moves. You can see the chipping damage which is present on the complete circumference of the lifter wheel. I have new Chevrolet Performance trays on the way, but unfortunately the cam will have to come out. Moral of the story: use OEM lifter trays.
mattbta
Frisco, TX
Damn. Bummer on having to pull the head, assuming you'll pull the other to put new trays on that side, too. And sucks about the cam, too. Sorry brother.
I panicked a bit after I put a second replacement head on (torqued and all)...couldn't remember if I tightened the tray bolt down because I pulled the lifters to see which way I had the oil holes. So far, so good.
Geotrash
Geotrash
Dave
Richmond, VA
Thanks Matt! Yeah, I’ll pull both heads and replace the cam also. Thinking of going with a VVT cam this time.
I hate that feeling that I forgot something. Glad you haven’t had any issues.
wsteele
Do you think the lifter trays were the original problem, even with the Vinci hardware?
Geotrash
Geotrash
Dave
Richmond, VA
That’s a good question, thanks for asking. But it’s starting to look that way, unfortunately. From everything I can find, that type of lift or roller damage is from sliding along the cam at an angle.
wsteele
I hope you don’t mind that I haven’t gone back to reread the early days, but did he ever bring up the trays as a possible source of the failure?
Geotrash
Geotrash
Dave
Richmond, VA
No. I raised it to him as a possibility given the unique damage signature but he was convinced it was a piece of debris that did it. Funny thing is that it’s easier to twist a lifter in that particular tray slot than it is the others, too.
Geotrash
Geotrash
Dave
Richmond, VA
I’m debating now whether to go with the same cam, with something slightly different, or back to stock. The BTR cam only has .553 lift but with the duration the ramps end up being pretty aggressive, and while it’s relatively quiet, it’s audible and likely harder on springs and lifters. It also lacks VVT. On the other hand I love the power is produces for towing, the idle lope, and the simplicity of installation.
Geotrash
Geotrash
Dave
Richmond, VA
Got the cam out this afternoon. Only that one lifter showed any damage, except one of them that had a small circumferential scratch around the roller, but hardly noticeable. However it corresponded with a second lobe that had considerable damage - looks to be from a piece of debris - possibly one of the chips from the failed lifter. Cam bearings look good.
Lobe with the damaged lifter:
Lobe with the fod damage:
Now I’m worried about debris in the rest of the engine. Whadda y’all think?
Geotrash
Geotrash
Dave
Richmond, VA
Whelp, decided to order a cam motion cam. Stage 2 but with smooth idle and designed for stock valve springs and with good durability, which has been my primary goal all along. I already have the upgraded springs installed, but this way they’ll last longer, and it will hopefully be mouse-fart quiet.
Specs are:
Duration at .050 - 212/220
Lift with 1.7 - .501/.501
Lobe separation 117
Intake center line 112
wsteele
On the concern about floating stuff, I think I would replace the top end stuff, take a close look at the oil pump.
I would keep a close eye on it cutting the filter apart and doing regular oil analysis to make sure the trends are in the right direction and call it good.
Geotrash
Geotrash
Dave
Richmond, VA
Oil analysis is a good idea. I will order some kits from Blackstone. I’ve used them on my aircraft engine for years, and they are legit.
Luckily there is a screen on the pickup tube, but it will only filter out things that have part numbers on them. Lol.
I’m just beyond pissed that the lifter trays have (with 98% probability) been the cause of all of this misery all along. Friends and family, do not let friends use cheap knock-off lifter trays, no matter where they bought them.
wsteele
I don’t wish any small business person ill, but when I go back and look at the chain of events, all I can say is you are a much better person than I.
I would replace my fuel pump to make sure I made it all the way, driven to his place of business and shoved those lifter trays up where the sun never shines. :)
You’re a kind man Dave.
brice715
