Entry Level Performance Mods
St. Louis
Uh, ok. Lol
I'm not saying anyones wrong.
All I'm pointing out is that the BlackBear dyno test doesn't test stock with aftermarket filter. All the others come with an aftermarket filter, except the Airaid MIT which is just the tube and only showed 1 hp gain in their test.
Also pointing out that the 2015+ engines are NOT the same as the 2007 - 2014 engines, Gen4 Vortec and gen5 Ecotec, a bit different technologies.
Many on this forum have experience with these mods on these vehicles, and many have owned them for many years and have "been there, done that"
Don't know why you feel so butt-hurt. Bad day?
Charlie207
LFOD, New Hampshire
I think it's worth mentioning that their dyno tests were on a 6.2l engine. Most of us have a 5.3l engine, and I'm sitting here with some spare cash (gun projects are all up to date, so obviously I need to spend my budgeted fun $$$) to upgrade my truck.
I found this website yesterday, via an archived post here, and it got me thinking about how similar this $130 intake is vs. a K&N intake kit at more than THREE times the price.
Lots of folks say that the OEM 5.3l intake is good enough that it's not worth replacing, and I imagine it's pretty darn good, but if I'm looking for better throttle response, would this be worth the $130?
probably, but if you are in CA. be sure to call them first and ask if it is c.a.r.b complaint, they give little to no info on there website which leads me to think it likely does not come with the sticker needed to pass smog.
Charlie207
LFOD, New Hampshire
Good call on the CARB compliance issue for CA residents. I'm in NH, so I'm G2G as far as legalities.
I can see those cheaper intakes adding a few horses over stock due to the large surface area of the higher-flowing (read: "lesser efficient") filter media. But, this will be at the expense of clean air going into your engine. Then, any gains would be negated as soon as the engine bay is heated up. There's NO way those "heat shields" seal the filter from the hot air trapped under the hood. Those designs with the bulb seal to conform to the hood are marginally better, but there are still openings all around for hot air to be sucked in.
You can't deny physics when maximizing the efficiency of an intake to feed the engine with all the volume of clean air it needs. You need air ducted in exclusively from OUTSIDE of the engine bay, a filter that cleans the air sufficiently while being large enough to flow all the CFM the engine can inhale and a smooth path to direct it all to the throttle body. Whether you accomplish all of this with $50 in materials or $500 will make no difference. You can't buy magic to circumvent physics.
Those $400+ intakes with the fully enclosed filter boxes satisfy all the necessities as well as scoring some flair points for their aesthetics. But, if you can live without the flair, keep your factory CAI. Polish up its performance sacrifices made in the name of sound muffling, manufacturing costs and "excessive-but-safe" stock filter design and you'd satisfy all the necessities just the same but at a 1/4 of the cost.
You can get a smooth air path to the throttle body with an Airaid MIT or (gasp!) a homemade setup from simple PVC pipe. Drop a quality air filter in the factory box and ensure the seal between the box and the fender is sound.
Charlie207
LFOD, New Hampshire
Good info. (EDIT: I'm in NH, and dust typically isn't an issue like it was when I lived in TX, and to some extent CA.)
Sound deadening isn't an issue; I could care less how much more induction noise there is.
I'm solely after removing all restrictions, so that the engine can breathe optimally. (short of adding forced induction) I would be fine with upgrading the cone filter at a later date once it starts to lose performance/efficiency/gets dirty.
To your knowledge, is there a higher quality drop-in filter that actually improves airflow? I've assumed a new paper filter was pretty efficient as-is.
Charlie207
LFOD, New Hampshire
NM, just bought the Speed-Engineering CAI. I saw that I had $60 in credit card rewards, so after shipping it's like $80 for a shiny new CAI.... for science, right?
Charlie207
LFOD, New Hampshire
I’m curious about these as well.
Group project/Show & Tell when it arrives.
iamdub brought up some good points in post #29 about heat, so I may just line the inside/outside with some metallic tape for a made up R-Value of 2.2, and call it a day. As mentioned earlier, I live up in NH, and it never gets that hot here for more than a couple weeks a year.
(actually the other problem, it gets cold... to the point several years ago the oil gelled in my 2004 Xterra. I had to get a chicken coop heater attached to my oil pan for a day before I could drain and flush the coagulated oil out. It was a couple weeks of -10, or colder.)
Edit: Upon further research it's probably more like an R-value of 0.02
I agree with the sound muffling. That's all those seemingly pointless tubes on the intake tube are for. Without them, the sound is very similar to the growl of a nice performance muffler.
I'm a huge fan of the AEM DryFlow drop-in filter. I've had one for over 50K miles and have checked/cleaned it twice at ~20K mile intervals. Both times, the intake tube was SPOTLESS. Nothing wiped up on a paper towel and no smear mark on the plastic where I wiped it. The filter works very well. I have no personal data on the airflow being increased, but it surely can't be worse than stock. Besides, the total area of that filter is WAY larger than the area of the throttle body. It's not a restriction. As for hard data on air flow and filtration efficiency, years ago, I read up on a test that included the DryFlow and a few other popular filter medias and the DryFlow stomped them all. My personal experiences with the DryFlow and other filters concurs with that test.
It's not the environmental heat, it's the heat from the engine. Particularly the hot air from the exhaust manifold that's less than 2' away from the intake box and trapped under the hood. Insulating the intake tubing or the filter box doesn't do much of anything since the air passing through it isn't in there long enough to be heated, nor are there any good elements to transfer the heat. What you need is the air going into the filter box to be isolated from the engine bay heat. This is exactly what the factory box does. It's weak point is the foam seal between the box and the fender. It's a thin foam that usually falls in when the adhesive fails from age, exposing the inlet to the hot underhood air. Replace this seal with something more robust, drop in a good filter (such as that AEM) and replace the tube from the filter box to the throttle body with a smooth path and you will have done all you can do.
Examples:
I wish I could find that test I was talking about earlier, but it was years ago and I probably read it in a Super Street or Sport Compact magazine or something. But, they tested the various filter medias with a tube (shop vac?) and something like a paper towel on the "clean side" of the media to see what the filter let pass. IIRC, they also tested volume (restriction) somehow.
More recent testing (although kinda lame and it's not the panel style we have):
Charlie207
LFOD, New Hampshire
I appreciate your breakdowns, but I already ordered a CAI. I'm interested to see what changes there'll be. I'm guessing it'll just be increased induction noise.
I saw you had ordered one. I was just adding to/completing what I had already posted.
Which intake did you get?
If you find a light coat of dust in that tube at your next oil change and/or it seems to feel weaker after it's warmed up or when sitting in traffic, you might be able to attach that tube to the factory box. Being $30 cheaper than the MIT, it could be an "MIT hack" for someone looking to get an intake.
Buford bubba
