Pulled the Transmission Pan Today
YukonRog
YukonRog
Grass Valley CA
Those chunks may be the source of the noise that started this whole transfer case/transmission endeavor.
I'm not sure since I used a stethoscope and the loudest noise was the front of the Transfer Case. And I did find several issues in the TC. Front Output bearing being the worst, chain, noisy clutch pack, pump knocking....
Multnomah Falls
Military
Noise can travel thru metal and deceive your ears. Not sayin' that's it but it's a maybe...
Yea, those roller bearings came out of a cage and some of those other pieces are likely from the cage itself. CRAP ON A *******!!!!!!!!!!!!!!!!!!!!!!!!!!!
YukonRog
YukonRog
Grass Valley CA
Yep I know noise can be deceiving. I can verify that when I pulled the TC's Front Output Shaft's Seal and spun it the sound was a rumbling noise like the tumbling rock sound I heard. So, at the very least the TC needed a rebuild anyways. I'm just very disappointed the Transmission is junk also.
Mudsport96
40.923,-89.488. Illinois
Well, there are a few possibilities.
1. That is part of the rear planetary torrington bearing.
2. The rebuilder did a shoddy job and those parts are from before the rebuild.
3. Might be pieces of the forward sprag, but i think they are too small.
Man, i should have said drop the pan before you went this far...
Well, if it is bad, its bad. If it was me, id shoot the moon. Put the case back in, and see if it still makes noise. That's what I would do.
Hell, when the 2-4 band in my Silverado was bad i was in denial and welded a booger on the pin tip to get me some more clamp distance for a month lol
YukonRog
YukonRog
Grass Valley CA
Well, I guess in retrospect I should have pulled the pan too. But it was shifting fine and the fluid looked and smelled good on the dipstick. So I rebuilt the Transfer Case and reinstalled it assuming all was good. And since I drained the transmission fluid when I was under it figured I'd just put a new filter and gasket in it. The gasket was leaking a little anyways.
So part of me wants to put it together and just see what happens but it's a $75 loss, or gamble, since that's what the fluid and filter kit cost me.
I don't know, flip a coin? I see lots of bourbon in my near future....
Mudsport96
Well, if you were near me, id give you some ATF out of my stockpile for a test.
Did you save the old stuff in a jug, maybe you could reuse it?
What bourbon you having tonight?
Having some Woodford tonight, out of my fathers day present bottle
YukonRog
YukonRog
Grass Valley CA
Nah I drained it into my bulk oil recycling bucket so it's contaminated for sure. I bought new fluid thinking it would all be good.
I can't afford to drink the good stuff the way I go through it so it's Evan Williams for me. I was weaned as a young biker on Jose Cuervo and Jack Daniels so my tolerance is different than most. LOL!
jonjonramblin
