Just Fishing
Can't fix stupid
Utah
Revenge is mine!!
Spider is in pain since i just sprayed her ***** ass with some pretty decent bug killer.
I hosed the storage unit down with that stuff, while wearing gloves and a gas mask.
I don't think i want to touch anything in there for a few months.
and i put the spider down before i left, making sure no eggs survived if she had any.
also
:rage:
Just Fishing
Can't fix stupid
Utah
Just Fishing
Can't fix stupid
Utah
Also more pictures.
Few try's trying to get the red belly of the btch
Note that this spider appeared to be in a ton of pain in these shots.
she tried to crawl away a few times, but i used the wand of the sprayer to pull her back out.
Just Fishing
Can't fix stupid
Utah
Ok enough please.
Oh and i totally took the hoe to the unit, so it counts. :waytogo:
And i dusted off the ol dueling tree, it's coming with me to the ol range this weekend.
If i'm alone, i think of it as a self resetting reactive target that also dings when i hit it.
Hoe is getting some miles this weekend with the wideband + logging.
Revenge is mine!!
also
:rage:
Scary! That's a Black Widow!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Really need some guidance guys. Like I mentioned earlier, my D/S front window won't go up or down. All the other windows, door locks, mirror controls etc work fine. I bought a new window regulator assembly and installed it tonight. Same thing. Nothing. I checked fuses, relays. Wiring. I know it has to be something stupid now that the new regulator didn't work. Wiggled the door harness between the door jamb and door. Pulled and checked the switch assembly. Relays under the dash. Fuse box under the hood. Really getting frustrated but trying to stay level headed and think it out.
Really need help with troubleshooting, wiring diagrams and such so I can trace the issue down.
Just Fishing
Can't fix stupid
Utah
Tried commanding it up amd down with the tech2?
St. Louis
Got a volt meter? Start checking for voltage starting at the window motor, then the switch, then wherever the switch gets it's power from?
Just Fishing
Can't fix stupid
Utah
If you don't have a volt meter, harbor freight has em for cheap.
I think i got a basic one from there for free a couple years back...
jpurdie
