Z71 Suburban Shock/Strut Replacement - Stock Height
NOSOK
Colorado
Any product recommendations for a 2011 Z71 Suburban? The truck is at 160k and is probably overdue for at least struts and shocks. It seems to be crashing pretty hard over bumps lately. I want to maintain stock ride height (or very close to it) and a reasonably comfortable ride. I never approach anywhere near the capabilities of the truck offroad, so I could get away with a softer setup potentially (as long it doesn't compromise on road handling, e.g. more body roll).
Dustin Jackson
@NOSOK Bilsteins are good, I would recommend the Bilstein 4600 series if you don't plan on leaving pavement.
NOSOK
NOSOK
Colorado
We'll leave pavement for camping trips but don't really go on anything rougher than I could with my old audi allroad with 7" of ground clearance. 4600 looks like a good option.
Dustin Jackson
@NOSOK I have the 5100s that are paired with heavy duty springs so the ride is a stiff but I like it because I can take dips, bumps, train tracks, speed bumps without worrying about bottoming out. I would not recommend the 5100s for anyone wanting a soft ride. Do some research on the 4600 I hope you like them
NOSOK
NOSOK
Colorado
When you put it that way the 5100s might be more my style. Do you know what came stock on the Z71?
Dustin Jackson
@NOSOK I have no idea, the dealership service techs said Rancho but I don't think Tahoes came with factory Ranchos until the 4th generation.
NOSOK
NOSOK
Colorado
This is what's on the truck now...based on the condition I'd say they're original. They don't look like any shock I'm familiar with, but from googling it seems they might be KYB.
Z71 come with Rancho shocks and that is what you have under there. Give me a moment and I will post up all the parts we used to do ours. You can substitute my shocks and struts and my front and rear jounce bumpers (bump stops) in place of yours for a slightly softer ride.
Of course, you'll have to decide what is necessary now to replace and what brands to use. For the most part, these are all GM Original Equipment and some ACDelco Professional.
The part numbers for the struts and shocks include both GM and ACDelco part numbers, they are the same with both numbers listed on the box. The rear springs I could not get in OE anymore, had to settle for ACDelco professional but the list shows both part numbers.
You can read about our experiences doing all of this inlcluding the tools we used and torque specs over at my build page, "Useless Information".
I do not recommend buying a ready to install strut assembly, they are not tailored to your specific vehicle and do not last long. Replacing only the strut without changing the other parts does little for ride quality, don't skimp.
You can in the interest of economy and half the life, substitute the control arms with ACDelco Professional or Moog's CK series, they are identical and I have the part numbers for both if interested.
Most of the items were purchased at Rock Auto with the remainder coming from a few dealerships selling their wares on Ebay. There is a 5% coupon code on this forum for Rock Auto.
It's been two months since we finished the front and about 2 weeks since we completed the rear and will be taking new ride height measurements soon. The rear shocks and springs and jounce bumpers made a huge difference in ride quality, more so than the front on ours.
NOSOK
NOSOK
Colorado
Awesome, thanks for the detailed list, that'll make shopping much easier.
I wouldn't mind a prebuilt strut assembly but from what I've seen there are no decent shocks available in those kits. And I have no doubts about the longevity of them either - my folks have an early 2000s Volvo that sees very light duty as a grocery getter. My father installed prebuilt strut assemblies maybe 5k miles ago and last time I saw the car it drives like the shocks are completely blown.
Dustin Jackson
@NOSOK My experience installing the MOOG 81244 spring onto the Bilstein 5100 was stressful to say the least but go slow and it can be done without much drama. I used 2 sets of springs compressors, I used the kind that are 2 threaded rods and each rod has 2 clamps that grab the spring. So in total I had 4 of these rods compressing the spring when I installed the spring onto the 5100. The one tool that would make this job easier is a tool to tighten the top nut of the strut while holding the shaft still so that you could tighten it. I am not sure of what to correct tool is called but I am sure there is one out there.
NOSOK
NOSOK
Colorado
Was the shaft spinning when you tried to tighten the nut? I installed Bilstein B8s (I think the same as 5100s) on a sedan several years back and had that same problem. IIRC I had to clamp the shaft in a bench vise to hold it.
Dustin Jackson
@NOSOK Exactly, I think I grabbed the shaft with vise grips and reached around the vide grips with a wrench. It wasn't confidence inspiring.
I used the vise grips to help remove the old one but the new insulator was in the way during assembly. Used the spring compressor again to get them to 37 foot pounds if memory serves.
NOSOK
NOSOK
Colorado
Looks like CarID has pre-built ACDelco strut assemblies. I wonder if these are worth a shot. I.e if the quality is decent enough they won't have to be replaced in 10k miles. Tempting to minimize install time but I absolutely do not want to do a suspension job twice in a year.
NOSOK
NOSOK
Colorado
Well I had to look through about 6 pages of ACDelco struts, but 540-624 seems to be the OEM front strut for the Z71.
NOSOK
NOSOK
Colorado
Did your truck have a significant change in ride height with the new suspension? I'm wondering if I can reuse the springs to save a couple hundred bucks. Also are any of the bolts torque to yield (i.e. can they be safely reused)?
That p/n chart is very helpful btw, I've probably referenced it 10x so far while building my CarID cart (would've gone with rockauto but I learned CarID has a 10% military discount).
Did you come to this number based on your 6XX and 7XX RPO codes?
I have not come across long term happy customers with the pre-assembled struts. They're very generic, not specific to a particular vehicle and use inferior parts.
Yes, the ride height was restored and she sits higher now, especially in the rear. I will do ride height measurements as soon as I refuel, in another day or so. Then compare with the measurements taken right before we did the work. Visually there's a difference and the ride is much improved.
There's a 5% off discount for Rock Auto on this website, might make a difference. It is SOP to replace the top nut on the strut. You could probably re-use the upper control arms nuts and bolts and cams if they are not rusty, same for the lower control arms.
Dustin Jackson
@swathdiver I am interested in seeing your hub to fender measurements. Between the MOOG springs and 2 inch spacers I am not sure how much my Tahoe is actually lifted.
Actually after reading my own signature it looks like I am running 2.5 inch spacers.
Rooster2000
