Bad fuel pump or something else? **Solved**
02Z71Raven
I'll try to attach a video, but basically it turns over and then immediately dies. I put a gauge on the fuel rail and read zero pressure until you turn the key, then it goes to 50psi and then when it dies, it immediately drops back down to zero.
I thought I had just ran out of gas, but I put about 3 gallons or more in it and I do get some out of the gauge during that short moment of pressure.
System says the video files are too big. I'll try to size them downa bit and post em.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Not holding pressure when off. Sounds like needs a fuel pump and always do the fuel filter at the same time.
But: Make sure, if you do replace the pump, that you check the pressure regulator as well. I was gonna look up but you did not share whether is flex fuel or gas and as of now, I am tired of guessing with no vehicle/engine info.
02Z71Raven
02Z71Raven
Didnt realize it mattered when it came to the pump, so I apologize. It's a VIN Z flex fuel.
I replaced the pump a few years ago and the fuel filter just a couple thousand miles or less ago when troubleshooting another problem. I'll swap the regulator just because I haven't done it yet, if it has one.
I assumed fuel pump was bad because I ran low on gas and was parked for a while on an incline. I think I ran it too long on E.
At least I don't have a full tank :Grenade:
02Z71Raven
02Z71Raven
Any recommendations on a pump only?
My assembly probably has less than 5k miles on it. Don't really need to replace the whole thing.
Thanks in advance.
Edit: correction... My pump and assembly was replaced during recent troubleshooting also. So the whole thing has less than 2k miles on it.
IMO, it needs to be diagnosed and then determine what is needed. You have some loaded statements. First: Yes it makes a difference if the 8th digit is a Z or a T, meaning gas engine and a different pump. Second: Replaced pump "a few years ago", meaning 3 years, 6 years...how many years and miles and what brand of pump. If it is relatively newer and a crappy brand, that can explain a lot. Don't cheap out and try just the pump, if you can find one. Do not assume the filter is still good, replace it with the pump:
BUT: I am still not convinced it is the pump unless you have a habit of damaging the pump yourself by running around close to empty all the time.
Being parked on an incline likely has nothing to do with it but I have been wrong before.
Do you trust yourself with the diagnostics or do you have a shop you trust?
Sounds like your existing pump is pushing pressure to the throttle body when the key is on and then dies because the pump just stops right then, when you release after the start. May have two problems: Pump and maybe ignition switch problem: Three choices of switch to pick from at RA.
to know for sure, you need to know if when it starts and release key and dies, does it still have spark, fuel pressure at zero or loses everything thru switch.
Hopefully others will chime in.
Flex pump for 2002 is AC Delco (Gold) MU2294 or DELPHI FG0810 (which might be OE). I replaced mine in my '04 a little less than 2 years ago and now the gasket is leaking and the evap test fails. I'll be pulling down my tank in the next few weeks to replace the gasket and lock ring and make sure it's well installed.
Don't know if we messed up something when we did it, but it was good for 22 months. I suspect that the bad canister vent valve didn't open when the ignition was off and allowed the tank to build up some natural pressure, maybe compromising the fuel pump gasket. Just a guess for now.
02Z71Raven
02Z71Raven
Yeah, the more I think about it, the more I question the pump as the culprit. It primes when the key is in the on position to a solid 50psi. Truck starts, then dies and pressure drops to zero. Makes me think that something isn't telling the pump to turn back on. Could be that I have to let go of the key, pulling it out of the start position and back into the on position.
Try again and it primes up and starts again, the immediately dies.
I've been troubleshooting electronics for 15 years, so I'm confident in my ability to test and troubleshoot, I just don't know what to test next.
Battery is on the charger so I'll try some other things tomorrow.
02Z71Raven
02Z71Raven
I can't remember the brand but I think it was a Delphi also that I bought at auto zone like 5 years ago. It had a lifetime warranty, so when I was doing some troubleshooting recently and it was in question, I just swapped it out under warranty.
02Z71Raven
02Z71Raven
Things I noticed today while poking around.
0 psi on fuel gauge. Turn key to on position, get 50-52psi for 2 seconds then drops immediately to 0psi. Truck tries to start for 1/2 second turnover then dies (just enough spark, fuel and air to fire some cylinders). Fuel pressure stays up at 50psi while key is turning, then 2 seconds after it died, it immediately drops to 0. To be clear, when I say immediately, I mean immediately, not a slow drain, the needles sinks to 0psi in a flash.
My wireless remotes no longer work. The ability to turn the auto headlights on and off no longer works, it won't change states. When I turn the hazard lights on, the lights on my climate control, 4x4 switch and headlight control switch all flash in unison with the hazards. I don't recall ever seeing that before.
I've inspected quite a bit of the connections around all of these areas including fuse panels and bcm and under hood and it all looks to be in good condition. No corrosion, nothing unplugged.
Still leaning on a major malfunction with ground(s) or the ignition switch. Hopefully someone here has seen this before and will chime in.
Try this: Remove both cables from battery and and let sit for about a minute, touch the ends together and then reinstall them and see what happens. Have heard of guys here having weird things like this type of thing and do a reset like I was saying.
I think between me and @Fless, we could be on the right track.
something to verify: one of the functions of the oem security system is to cut the fuel pump off, so a start and die is the symptom (depending on the year) the security message may be flashing or the security lock light will be illuminated. in either case a key relearn is needed.
02Z71Raven
02Z71Raven
I could be wrong, but I'm leaning toward BCM.
I removed the battery yesterday to recharge it, so that box is checked.
Wireless remotes, auto headlights and VATS all require BCM. None of mine work now.
I tried the security relearn procedure, but security light stays on alternating back and forth with battery for well over 11 minutes. Should go out after 10.
I completely removed the bcm to check serial number (going to grab a used one tomorrow for testing) and it acts exactly the same without it installed, no changes to anything.
I think it's toast and I think I know why.
I'll do some more testing tomorrow when I get back with a wheelbarrow full of spare parts (sale at the wrench a part) and post an update.
Thanks for all the tips, and yes I will check those grounds just in case. Can't hurt.
Have you checked the voltages in and out all of the TBC fuses in the Instrument Panel Fuse Block?
clandr1
Dallas/Fort Worth, Texas
Is your fuel pressure regulator integrated into the fuel pump assembly (mine is), or is it located on the fuel rail near the intake? Believe with you having a 2002, it might be on the fuel rail. If so, I'd change it for a new one since it's cheap and easy to access.
My truck started having issues starting around 140k miles, and it turned out the pump itself was fine, but the FPR (which is built into the pump assembly) had failed, so I had to replace the entire thing.
02Z71Raven
02Z71Raven
No luck at the salvage yard. I'll check those fuses you mentioned @Fless .
Ordered a Fuel Pressure Regulator. It is on the rail, so it'll be a quick swap and likely needs to be replaced even if it isn't the problem.
Past that, I can try another BCM, but I'll likely just drop it off at the shop. They're going to be pulling the motor and doing cam upgrade and tune anyway. They'll just have to find this problem and fix it to.
Is this the FPR you ordered? The one I listed several posts ago: https://www.rockauto.com/en/moreinfo.php?pk=344238&cc=1380372&pt=6124&jsn=962
ibarra503
