Ok good deal. Thanks for the fast replies. I also have another question if any of you all can give some insight. Normally I don't pay much attention to the oil pressure gauge but I did notice on a 90 degree day that the oil pressure gauge is sitting on the first line. I'm assuming this is 20 psi. This is is at idle. It never drops below this. When I drive around the pressure will increase. I thought the gauge was usually higher than that but like I said. I normaly don't look at it. While driving it reaches 30 psi and if I floor it will reach 40 or above. This is all seen in the torque app. What are the normal oil pressure levels while it's hot out and at a norm5 operating temperature? When it's cooler in the morning (65 degrees) it will idle at almost 30 and drop to around 25-30 psi while driving normal. Oil change has about 3k miles on it at the moment and I use either Mobile-1 5w30 or Pennzoil Platinum 5w30. Here are some pics of idle and driving on highway. Let me know if anything looks out of place. Again thank you all for the help. It is much appreciated.
Brandon
