Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
i think i have everything i need to get the wastegates into the downpipe this weekend....except welding gas :emotions122:
tank is below 1000psi or so...may have enough to tack it all up
also got a chance to let it sit and idle for about 45mins+ with ac on full blast - wanted to see how the new radiator/fan setup did. it stayed right about 185-187 for like 25 mins then slowly started going up a degree every 5 mins or so. i dont remember what my fans are set to do but i let that go on for a bit till it was like 192*, turned off a/c and kicked both fans on high and it was under 180 in less than 2 minutes according to the log.
randeez
randeez
south florida
Define "stock." ;)
I vote for a thread title change. Something to the effect of "Randeez Ruins His Denali". Or, put it in the tech forum- "How To: Ruin a 2013 Denali"
randeez
randeez
south florida
Took it for the maiden voyage this morning...I need a few more clamps for the charge pipe tho...builds like 5psi and blows out the coupler lol
Ordered some more 1-3/4 90s for the wastegate dumps...summit stainless pipe is garbage. Wouldn't fit into any of the fittings, flex sections, vband ends.
And I think I've got an exhaust leak on bank 1...fuel trim about 10-15% higher than the other
randeez
randeez
south florida
found exhaust leak, the vband to the header wasnt even tight lol. theyre the quick release clamps so it was just on there as tight as i had the qr set
stop at two places and couldnt find any ~4" clamps (was just going to grab some worm gear) but none of those either so i ordered a couple tbolt ones
i put a couple gallons of 93 in it cause it was about out of gas, e85 is about 20mile trip and wanted to do a couple more small runs before i made that round trip
randeez
randeez
south florida
i tried clamping the charge pipe...some fuggin cv axle clamps, tyraps, anything else i could find - i was kind of worried it was just sluggish as hell but it was just separating the coupler.
the only halfassed pull i made the wastegates screamed when they opened up :eek: then promptly blew the charge pipe apart
log showed pull starting about 2500rpm>by 3000rpm was just beginning to make boost> by 4000 about 7lbs> and by 5000 over 12psi, i think thats how about what ive got for springs in the wastegates but didnt see it table off before charge pipe blew off. tps about 60% so not really floored - and with an air filter over the turbo, stack almost always helps spooling up a little faster
I guess we're just gonna have to imagine all those lovely sounds. :( Really looking forward to seeing those fire-breathing nostrils on the hood in action!
Now I'm trying to think up befitting custom plates:
WYTDRGN (White Dragon or Draggin')
BRTHFYR (Breathe Fire)
BRKDNLI (Broken Denali)
WSTDYKN (Wasted Yukon)
IBROKIT (I Broke It)
ITSJUNK (It's Junk)
randeez
randeez
south florida
ITSJUNK (It's Junk)
it will never live up to your imagination
randeez
randeez
south florida
sooo it runs pretty good. a little on the lean side from where the tune was with old turbo. wants about 10% more fuel in boost if thats any indication :rofl:
narrowband o2s.... is something to do with the injectors - at 43psi, bank 1 starts going lean at any speed/load/rpm like 7-8% off from bank 2. i noticed when i turned on the big pump (and pressure goes up to ~60psi) the narrow bands match within a .5% so i just drove around with it on for a good bit this afternoon.
got the clamps on the charge pipe and am able to make some pulls. i think i put 12lb worth in springs in the wastegates...log shows about 15psi so not too far off. a little more than i wanted for "minimum" boost . injectors will be high 70% duty cycle when i get the afr closer to where i want
IATs are staying good, just touched on 100* on the couple pulls i did this afternoon. only had the pump on about 60% so could prob keep it down a little better but 100 is nothing and temp drops right back down afterwards with so much coolant in reserve
and i really shouldve waited till i had the hood pipes up another inch or two...cause i already started blowing the paint off the hood :emotions122:. I sort of wish they werent thru the hood cause it would be a ridiculous sleeper, but holy ef when they open up its loud, and youre looking thru it distorting the air like a jet engine as it blows out
engine coolant temps have been good, they do wander from like 180 up to as high as 210. if i just cruise it for a little bit, turn off the ac, temp comes down within a few mins tho
Conedaddy
