Welp broke something serious
ls1frc
Ha it never ends lately. Fixed the motor problem...
Now I got a driveline problem.
Engine is feeling incredible since I fixed the tune, so I've been having some fun with it last couple days.
On a 1-2 shift, I broke something. Something is seizing up intermittently, most notable around slower turns. A terrible driveline clunk with a reduction in vehicle speed and RPM. Doesn't seem to be related to shifting at all and I still have all 6 gears. Going 60 mph down the highway is fine and the gears are shifting normally. I visually inspected the driveshaft and u-joints but didn't see anything off. Nothing is cracked or losing fluid in either the rear end or the transfer case either.
When making slow left turns it's at it's worst. Doesn't appear to do it in neutral.
Any tips on how can I rule out transfer case, driveshaft, differential??
It's really bad. I made it home from the gym, but I will be renting a car this week before it breaks more stuff. You hear it really bad around the 21 second mark.
97YukonNZ
Sounds like you may have blown the differential. I would think if it was the transfer broken it would not be driveable.
All gears working,does 60mph. Only has trouble at a slow turn. Sounds like diff.
L
ls1frc
That's what I was leaning towards
Bill 1960
Testing the Limits
Assuming this is 4wd and not AWD. Symptoms are consistent with damaged spiders in the rear.
L
ls1frc
Thanks all will test tomorrow.
Car-Part.com has no used assemblies :-/
Any advice?
L
ls1frc
I knew my power was back! Feels like it gained 100 ft/lbs since I fixed the tune after the terrible track day. Once I fix this, 100% torque management going back in lol. I was running about 50% TM and 1-2 shift was about 200ms.
L
ls1frc
I dont know much about rear ends. Just need quickest way to get it driving again.
I will pop cover off tomorrow and look in there
L
ls1frc
What all parts I need? I wanna buy it all and just take to a shop
L
ls1frc
Ordered truetrac and bearings. Gonna diy it doesnt look hard.
Bill 1960
Testing the Limits
Based on your own comment re not knowing much about rears I will recommend some caution. It’s not a hard job, but neither is it an easy job to DIY without some specialty tools. Patience and precision is necessary for the setup to run quiet and last. You can do it, just take your time. The chances of it being a simple remove and replace parts swap without some adjustments to gear mesh are slim.
You may need new gears because if they ate some chunks of whatever broke, the teeth may be chipped.
Geotrash
Dave
Richmond, VA
+1, setting up the mesh is one of those things where experience with doing it many times is helpful. Setting up a diff is one of the few things I will outsource in my cars. I've rebuilt a ZF 5HP-24 automatic transmission (a notoriously complicated beast) on my bench, but I leave diffs alone. If you decide to tackle it though, I'll be watching with interest to see what you learn in the process. In my experience with watching your work through these pages, I know you're both thoughtful and thorough.
L
ls1frc
Ok, I was just watching some youtube vids. It looks pretty simple to set the backlash properly with the dial indicator and shims. I'm not removing the pinion gear or anything, so I thought it could have been a DIY.
If it needed new gears as well, I'll take it to a shop. I'm gonna pop the cover off and look in there.
Bill 1960
Testing the Limits
Yeah, if you leave the pinion in place it’s a lot less work.
My preference, if I’m tearing down a high mileage diff, I won’t leave old pinion bearings and seals in place.
HD_LS
Slightly off topic: Is there a truetrac or any other non-open differential available for the front axle?
Geotrash
Dave
Richmond, VA
It may well be that easy. I’ve just never done it and have read enough horror stories from people screwing it up to be willing to let a pro do it. Then again, the last time I had to have a diff rebuilt was in my old suburban and I was living in Colorado, right down the street from one of the best 4x4 and driveline shops anywhere.
Bill 1960
Testing the Limits
Unfortunately no. Deemed too weak by the aftermarket to offer anything.
Dh1280
