How to get 700hp (2017 Denali)
gat0r
DFW
RAM TRX
Just buy it....Comes with a warranty
Runs on gas
although nice & does have warranty, its 700 crank, not RWHP
& seems it also has a $25k market adjustment.... not worth that.
GONMAD is pretty close to that power now
FrankU
Babylon New York
25K "market adjustment" that's nucking futs !
GONMAD :waytogo:
GONMAD510
Looks like they made them easier to install with that layout. Mines almost impossible to get to the passenger side Allen head bolts that mount the blower to their intake. How hard was that to install?
Overall the kit was fairly easy to install. Came with everything from the SC and all of the intercooler lines along with a coolant reserve tank. The only bolts that were hard to get to were on the back of the SC. It was tight back near the firewall. Dropped 1 bolt and never found it. It never hit the ground of course. Had to go pick up a replacement. The other really hard thing was replacing the back passenger spark plug. I was using swivels and extensions from weird angles to get to it.
Thrust
ICT
I found the easiest way to get to the aft spark plug on the passenger side is to remove the wheel well liner. Yeah that takes time too, but I felt it was way easier to get to the plug by doing this.
GONMAD510
That is kind of what I ended up doing in the end.
FrankU
Babylon New York
Put the socket on the rear plug , just the socket. Use a 3/4 open end and turn the socket.
Works fer me.
That’s what I started doing after I installed longtubes. I also trimmed the shield around the ac that was right there trying to cut my knuckles.
GONMAD510
So I have a little delay in getting the dyno numbers. After the heads were torqued down for 5 days with new ARP studs, 1 of the studs snapped and shot out into a wall. They did not hear it snap but they did notice one of them was missing when they went to put the valve covers on. They were not over torqued either. It snapped right at the point where the threads started. IMG_0256003.jpg
So I have a little delay in getting the dyno numbers. After the heads were torqued down for 5 days with new ARP studs, 1 of the studs snapped and shot out into a wall. They did not hear it snap but they did notice one of them was missing when they went to put the valve covers on. They were not over torqued either. It snapped right at the point where the threads started.View attachment 305181
I have never heard of an ARP bolt breaking. Do you know if the shop followed ARP’s install instructions or the OEM ones. I know their stuff is spec’d for different torque values and a lot of it needs ARP’s special thread compounds. Its possible they were counterfeit bolts also. Regardless, that sucks.
randeez
south florida
is the rest of it in the block still? or were they able to get it out
GONMAD510
Yes they did follow their instructions. They use ARP for everything.
GONMAD510
Yes the other part is still in the block. They had some special tooling made to hold the drill bit straight in the hole so they can drill right in the center. It is broke off 1.5" down in the hole where the threads start in the block.
Probably water or oil in the hole then. Or somebody just fkd up. Hope they were able to get the broken stud out?
Edit: just read the updated post, hope they get it out.
GONMAD510
Well finally on the dyno. Machine shop ******* up my block trying to get the broken stud out. Ended up with an LT4 in the tahoe. Win Win for me since the internals are better than the ones in the L86. Here is a dyno pull at 12PSI. Made 660RWHP and 661 RWTQ. Going to put some ethanol in it and see what it does. Was trying to attach a short video of the dyno run but I can't do it.
fozzi58
North Jersey
Nice. About waiting for my street tune from BBP so I can get my new whipple running at max power. Only a 5.3 for me but them tires dont hook at all under 40mph. I'm kinda scared to turn off the traction control. The rear end has gotten awfully squirrely on me eve at 25 or 30 mph
Drewphil
