RAM TRX
Just buy it....Comes with a warranty
Runs on gas
although nice & does have warranty, its 700 crank, not RWHP
& seems it also has a $25k market adjustment.... not worth that.
GONMAD is pretty close to that power now
RAM TRX
Runs on gas
25K "market adjustment" that's nucking futs !although nice & does have warranty, its 700 crank, not RWHP
Yes it is a 2.9 whipple. Thank you. I can't wait to see what it is going to put down later this week. Will post up the graph once I have it. Try to have the 91 octane and E85 overlayed.The Whipple may be a 2.9 ? Congrat's on the nice numbers. Strong runner !
Looks like they made them easier to install with that layout. Mines almost impossible to get to the passenger side Allen head bolts that mount the blower to their intake. How hard was that to install?Here is the pic of the SC right after I installed it.View attachment 297787
Overall the kit was fairly easy to install. Came with everything from the SC and all of the intercooler lines along with a coolant reserve tank. The only bolts that were hard to get to were on the back of the SC. It was tight back near the firewall. Dropped 1 bolt and never found it. It never hit the ground of course. Had to go pick up a replacement. The other really hard thing was replacing the back passenger spark plug. I was using swivels and extensions from weird angles to get to it.Looks like they made them easier to install with that layout. Mines almost impossible to get to the passenger side Allen head bolts that mount the blower to their intake. How hard was that to install?
That is kind of what I ended up doing in the end.I found the easiest way to get to the aft spark plug on the passenger side is to remove the wheel well liner. Yeah that takes time too, but I felt it was way easier to get to the plug by doing this.
That’s what I started doing after I installed longtubes. I also trimmed the shield around the ac that was right there trying to cut my knuckles.I found the easiest way to get to the aft spark plug on the passenger side is to remove the wheel well liner. Yeah that takes time too, but I felt it was way easier to get to the plug by doing this.
i use pivot head ratchet with 1" extension on plug socketPut the socket on the rear plug , just the socket. Use a 3/4 open end and turn the socket.
Works fer me.
I have never heard of an ARP bolt breaking. Do you know if the shop followed ARP’s install instructions or the OEM ones. I know their stuff is spec’d for different torque values and a lot of it needs ARP’s special thread compounds. Its possible they were counterfeit bolts also. Regardless, that sucks.So I have a little delay in getting the dyno numbers. After the heads were torqued down for 5 days with new ARP studs, 1 of the studs snapped and shot out into a wall. They did not hear it snap but they did notice one of them was missing when they went to put the valve covers on. They were not over torqued either. It snapped right at the point where the threads started.View attachment 305181
is the rest of it in the block still? or were they able to get it outSo I have a little delay in getting the dyno numbers. After the heads were torqued down for 5 days with new ARP studs, 1 of the studs snapped and shot out into a wall. They did not hear it snap but they did notice one of them was missing when they went to put the valve covers on. They were not over torqued either. It snapped right at the point where the threads started.View attachment 305181
Yes they did follow their instructions. They use ARP for everything.I have never heard of an ARP bolt breaking. Do you know if the shop followed ARP’s install instructions or the OEM ones. I know their stuff is spec’d for different torque values and a lot of it needs ARP’s special thread compounds. Its possible they were counterfeit bolts also. Regardless, that sucks.
Yes the other part is still in the block. They had some special tooling made to hold the drill bit straight in the hole so they can drill right in the center. It is broke off 1.5" down in the hole where the threads start in the block.is the rest of it in the block still? or were they able to get it out
Probably water or oil in the hole then. Or somebody just fkd up. Hope they were able to get the broken stud out?Yes they did follow their instructions. They use ARP for everything.
