Super cheap electric fan question - see pic
Stonefort
Ok so I saw this super cheap brand new electric fan for my 2004 Tahoe on Amazon WITH free shipping for 35 bucks totall.....I figured it was worth the gamble. It just came in. I don't see any part numbers, brand or anything. Would y'all mind looking at the pics to confirm if this fan will fit???
20210529_192526.jpg 20210529_192553.jpg 20210529_192620.jpg 20210530_005836.jpg
corvette744
2004 Z-71
Northern illinois
You will either have to measure the width and height of your radiator to guess that.My questions would be were are the relays and wiring for that price no way they were included.ALso how does it mount to the radiator i see holes on the bottom.Does it give you the cfm of the fans.What about posting the link from amazon that you bought it from.
Super Moderator
Elev 5,280
Dorman brand. They look very close, 5 blade and 7 blade fans. The second pic is upside-down and the top mounting holes are shown. The ears on the sides of the fan slide down into hooks on the side of the radiator. Missing the bottom and top rubber bumpers/mounts but those may be on your current fan shroud.
EDIT: pics of (dirty) OE fans here:
https://www.tahoeyukonforum.com/thr...ahoe-yukon-today.12502/page-3454#post-1504170
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
corvette744
2004 Z-71
Northern illinois
Still dont no if your installing a new harness or have relays for it.Hope your not gong to run a switch with wires directly to it.If so bring some heavy duty cable cutters and a fire extinguisher.:flamingdevil:
those holes are actually the top and you would normally swap the rubber bushings from your old fan shroud to this one, that is a fan & shroud only Dorman does not sell a "kit" to convert to electric. it will physically fit 00-14 1500 suv's and pickups, avalanche, etc
Stonefort
Stonefort
Sweet thank you for the info!
620-653 is a factory replacement for a 34" rad it looks like. Nice find. You can definitely make that work
Awesome thanks! And thanks for the other replies guys.
Have a couple other questions if yall don't mind.
I haven't been able to get in touch ScottyBoy about the relay harnesses he sells. Has anyone heard from him lately? Anyone know of an alternative harness that works well if I can't get in touch with him? We have one junkyard I might be able to grab one from. But it's not a you pick, I'd have to explain to them very carefully to get the two wires going into the harness.
randeez
south florida
if you cant find him, theres a few companies that sell a conversion harness pcm of nc, nelson performance, racetronix
most just have power and ground connection and then trigger wire from ecu or temp sensor
agmanw8n
