Not Sure If Your Rear Main Seal Is Leaking?
mattbta
Frisco, TX
Now that I've fully hijacked jonnytahoe's thread...this was the first and only transmission I've dropped. Had to replace the slave cylinder that I accidentally broke when installing the long tubes. Was a good time to upgrade all the hydraulics and pressure plate/clutch.
This was 20 years ago and I still have no interest in doing that again and it was just a T-56.
Back to your scheduled rear main oil leak thread!!!
Greg Kulbick
Tallahassee, FL
View attachment 279176 View attachment 279175
Yeah, I know that set up. My days bench pressing transmissions into place are well behind me.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yep, my last trans dropped on top of my stomach and then shift sideways to get to ground, from under a Camaro, are long gone.
Larryjb
Ouch Ron! I'm not a big guy, so that probably would have killed me.
I had a bit of a scary moment with my tranny jack. It was secure on the jack, but the tilt feature did not hold as I separated the tranny from the rear of the engine. Afterwards, I realized that the adjuster bolts had a locking nut on the end that was rotating off. I can't remember exactly what I did, but I believe I wiggled the transmission off onto some blocks, resecured the locking nuts with some locktite. At least I was smart enough to use ratchet straps holding the tranny on the jack, otherwise it would have gone sliding right off. The other thing that got me was that while the base of the jack was level with the tranny at first, and the base seemed firm, the tranny is very front heavy and was enough to tilt the base forwards. This wasn't a cheap jack, but it wasn't the most expensive. It was designed for transmissions.
So, TGF tranny jacks, but inspect them first.
torqwench
Henderson,Nevada
Crazy timing. Here's mine this weekend after blasting it clean with brake cleaner. Started it up and saw this: (It's either rear main seal/cover or I did a bad job on the oil pan gasket or BOTH) Thoughts? All new stuff within a year: Oil Pressure Sensor, Camshaft Position Sensor, Crankshaft Position Sensor, Oil Pan Gasket, Valley cover Gasket, new Blockoff Plate.
View attachment 278891 View attachment 278892 View attachment 278893 View attachment 278894
same thing on my 05 tahoe! every time i stop i get 3 drops unless on an incline then i get a puddle, mine appears to be more of a the bottom of the block has a seam running horizontally around the motor , it seems to be the culprit.
The way you describe it, sounds like a rear main because when it leaks it can puddle in the bell housing and then the oil moves as you stop and a few drops come out but if on an incline long enough it would leave a puddle as it comes out of bell housing. IMO
JonnyTahoe
JonnyTahoe
Minneapolis
No hijacking worries here. Many rear main threads are already on here.
JonnyTahoe
JonnyTahoe
Minneapolis
Great pictures.
Drewphil
