Super Moderator
Elev 5,280
Nuttin' to mine today, but yesterday I pulled the cluster out of my neighbor's Hoe. Started the cluster re-work today. I'll fix dead bulbs and replace the stepper motors. Here's a pic of the board with the old steppers and the two dead backlights marked with red:
No LED conversion?
Super Moderator
Elev 5,280
No LED conversion?
Not on this one. It's the neighbors' Hoe that needs a tranny they can't afford so they're not driving it. They're not sure what they'll do with it, they owe a pile of money on it and I offered to clean up the cluster. It's good practice for me and I'm doing it for free just to see what it takes.
That’s awesome for you to to that.
Sam Harris
Good on you Steve. [emoji106][emoji16][emoji631]
Super Moderator
Elev 5,280
Thanks, @Sam Harris and @Rocket Man. They may eventually get a tranny for it so at least for now they'll be able to tell how much gas is in it. They tried to start it the other day -- they run it every couple of weeks or so to make sure it runs -- but it was out of gas and they couldn't tell by the gauge. It was pointing straight down. We added a couple of gallons and the 4.8L fired right up.
EDIT: if I had the wherewith-all and a decent place to work I'd help them with the tranny. They're good neighbors and help out where they can.
Scottydoggs
NJ
AUX fan. I am in the tropics, this helps a lot when just idling with the A/C on.
i know its not a huge fan, but you got a relay wired in? they put far less of a strain on the battery when you use one. i did twin 16 inch fans, and removed my clutch fan years ago. i put them on a switch and a relay for each fan.
5x10
I bought an 05 Escalade esv a little over a month ago
82k miles on it
Had the cluster redone
Had a deck put in it for Bluetooth/ CarPlay
In the process of changing all the bulbs to led and I ran into an issue with the door light
Bulb is too big
Light casing seems to be glued together
Any advice on this one?
Thanks!
77754192-D3D6-499F-8FEE-695DBAF7BD19.jpeg 4CC5A9FE-6AD7-4DAF-827E-AF6F80DA3BC0.jpeg
